Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-28-2008, 12:33 PM
jmadsen's Avatar
jmadsen is starting off with a positive reputation.
Road Draft Tube
Do you have to have one? PVC valve?
I am going to have a flathead rebuilt for my truck and the engine currently doesn't have one (its missing). any specific info concerning draft tubes or alternates would be greatly appreciated.
Thanks
Josh
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-28-2008, 02:54 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
The benefits of the PCV:
Positive, works all the time, not just when you are moving over a certain speed.
No frothy mess dripping on your driveway.
No oily haze around the breather.
You don't have to have one, but the draft tube is designed to pull fumes out of the motor. So, if you don't have one, you have some additional risk of internal sludge/goo buildup, or, wherever he tube attached, a mess there.
  #3 (permalink)
Old 04-29-2008, 03:39 AM
55 f350's Avatar
55 f350 is starting off with a positive reputation.
ross { albuq} had a list of parts ya need to put a pcv in . i got it somewhere but like so many other things it's been on hold for a freakin' coons age now .................. the pcv would be much better , although the people walking up to me telling me my truck has a bad exhaust leek and it's smoking is kinda funny ................
__________________
thats because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { dont } know especially to newcomers. were on a mission to impress you and make you beleive we are all knowing !
  #4 (permalink)
Old 04-29-2008, 10:53 PM
jmadsen's Avatar
thanks for the info,
I just got a price quote for the rebuild and machine work, Ouch!
  #5 (permalink)
Old 04-30-2008, 08:46 AM
galaxie641 is starting off with a positive reputation.
Alright I'll bite, how do you put a PCV in when there are no valve covers, and no overhead vlaves for that matter?
__________________
'48 F1 Flat6
'51 F3 Flat8
'64 Galaxie 352 4bbl
'68 F150 390
'72 F250 400/C6
'97 F150 5.4L
  #6 (permalink)
Old 04-30-2008, 05:32 PM
jmadsen's Avatar
this from my question also posted on the MSN Flathead forum
Ford Flathead 1932 to 1953
Josh
  #7 (permalink)
Old 05-01-2008, 08:21 PM
effie_man's Avatar
Fatty driving the Flatty!
effie_man is starting off with a positive reputation.
i plan on reworking mine so it goes back into my motor and burns up and eliminate it al together without a pcv
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #8 (permalink)
Old 05-01-2008, 09:52 PM
seven up's Avatar
seven up is starting off with a positive reputation.
I ran a hose from the draft tube to an original ford carb spacer with the pcv attachment. And an inline pcv check valve. It needed a step down barb fitting. It's on a '60 OHV.
Cheers
  #9 (permalink)
Old 05-01-2008, 09:57 PM
effie_man's Avatar
i plan on running a tube through under my intake and through the spare vent in the fuel pump to one of my carbs and burn off the gasses through the motor again
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #10 (permalink)
Old 05-01-2008, 11:47 PM
Quote:
You need the PCV valve to regulate this and prevent sucking oil directly in, and not have the connection just be a big vacuum leak. Look at pcv set ups and duplicate one.
  #11 (permalink)
Old 05-02-2008, 10:20 AM
effie_man's Avatar
my flatty parts distributor does it to al his motors that he builds and he nevers has any problems. Hes a reputable guys who has been cited as a source for various hot rod magazine articles
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #12 (permalink)
Old 05-14-2008, 01:57 PM
rcav8or's Avatar
If you use it, SUPPORT IT
rcav8or is starting off with a positive reputation.
Quote:
Josh - you've kept us in suspense long enough!!! What was the quote? I'm curious, because I've debated building my "spare" block, just to have a spare...
R
__________________
Roger Phillips
Oxford, IN
Be an FTE supporter! Best $20 I EVER spent!!
Click the link for pictures of my truck:
1951 Ford F2
  #13 (permalink)
Old 05-14-2008, 03:23 PM
jmadsen's Avatar
About $3600 which includes new timing gear upgraded cam, valves, align hone (which may not be neccesary),hardened valve inserts, can't rmember everything else but that was pretty much a worst case scenario, so hopefully it would actually end up being a lot less than that, all done and said. oh and it didn't include reassembly (just the valve assembly) I am still going to get a second quote for the same options and see how they compare.
I just need to remove the valves and cam at this point then I will get it in and magnafluxed to make sure its rebuildable. then it may sit a while until I find some $
  #14 (permalink)
Old 05-14-2008, 09:10 PM
rcav8or's Avatar
Wow, that IS a lot...more than I figured, when I found out my block is probably good. You have gone a little further than I would have, but, when I got there, I know I would have gone ahead, and done it right...guess my $1200 rebuilt motor IS a good deal!!
Thanks,
R
__________________
Roger Phillips
Oxford, IN
1951 Ford F2
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
