Its a scam, but with just enough truth to capture the attention of folks who don't completely understand how their engine functions. Yes, and engine will run quite nicely on Brown's gas. And yes, you can utilize electrolysys to make it. But even the best of those gadgets doesn't even make enough fuel for you to idle the engine. Sure you could super size the electrolizers, but then you have to carry around all the heavy stuff you made, and you need several larger alternators to run them....so you gain....nothing. If one can design the very best unit that makes the gas with the least electrical input, you might, just might, be able to alter fuel economy by useing the hydrogen to speed up the burn in the cylinder and increase the engine's thermal efficiency. But this is going to be an incremental change, not the 50% or doubling or tripling that some of these guys claim. I'll bet some of the folks selling these are soon going to claim to be Charles Nelson Pogue's grandkids or something and try to sell us a copy of his 'lost' blueprints.......DinosaurFan, on an old 'puter that work threw out.
geez,i guess next you guys are going to tell me those magnet things you strap on your fuel lines don't work either. looking into the flux capacitor,it seemed to work in Back to the Future..........
I've seen and played with the electroliser and ran it on 3 amps and 12v bubbling the whole jar that is less power than ur radio and producing alot of hydrogen. And on a EFI u need to build a MAP enhancer to reduce amount of fuel ur vehicle is using by changing resistance going to cpu from the map so ur reducing not eliminating use of fuel if u try to remove gasoline completely the say use a electroliser the same size as ur tank
No matter how efficient that electrolizer is the hydrogen it produces will never put that 3 amps back into the system.
__________________
'97 F-150 XLT S/C 8' bed Leer fiberglass shell
This same thing has popped up on several threads. Every time there's a sudden increase in fuel prices, it comes up again. The first time I saw it was in 1973. It didn't work then, and it won't work now.
When the folks who know what they're talking about (and they're pretty easy to pick out of the crowd) tell you it's a scam, it's a scam. For those who keep insisting that it will "improve the efficiency of combustion" or some such ill-advised techno-babble, I say, "Go ahead and spend your money.... I'm done trying to convince you it's a stupid idea."
If a car were running on pure hydrogen in order to get about 300 miles per refill you would need to compress a hydrogen tank the size of your gas tank to about 10,000 PSI to hold enough hydrogen gas, or freeze it to the point it becomes a liquid. Now, a mason jar cracking water molecules simply isn't going to product enough hydrogen to assist gasoline for even cycle of all the cylinders. It produces mere bubbles of hydrogen --- it takes enormous amounts of hydrogen to run an engine, and significantly large enough that a jar of water boiling off hydrogen isn't going to make a dent. The impact on the combustion cycle is non-existent, especially since the PCM cannot measure the hydrogen and puts just as much fuel into the cylinder. Not only is the engine's efficiency not going to increase, its going to decrease because of the added loaded from the alternator.
Even the most efficient water splitting in the world is horribly inefficient. Its a mater, established technology and its simply a fact that it takes a lot of energy to split molecules.
This same scam was around in the 70s, and now its back. Are there really people this gullible? Are they the same people who didn't pay attention in science class because they never thought it would apply to their life? Well... it certainly applies now --- too bad some slept through class!
__________________ -Ken
If you need to get in touch with me email me at ftsservice at gmail dot com or via AOL IM: motorhavenken. The best is yet to come....
I'm surprised that this wasn't posted here yet: Yahoo!
Of course, this still doesn't you can use water for gas, it only means that they could fool Reuters.
Bonus points to those who can guess how this one 'works'.
That car does not use an internal combustion engine. They stated that the car releases electrons to power the car which means it uses the water to generate electricity which powers the car.
__________________
I would like to see some details about how the car in the reuters video actually works. I have a simple rule, if I don't understand it, I don't believe it.
However, it does look pretty legit.
They can state anything, but 'releasing electrons' is not like opening the faucet, or releasing some gas. As a matter of fact, I don't think I've ever heard this term in this context before.
The reason they didn't provide more details because in all likelihood, it's a scam. Or at the very least, they presented some very misleading information.
