I have a 2001 ford escape 3.0 v6 with the emissions light on, I checked the code came up with p0402 egr flow excessive. I have replaced the egr valve,
egr valve solenoid and the egr pressure sensor. I reset the light after I
replaced each item, and the light comes back on. I checked all my vacuum lines they checked good. And if I had a leak I dont think that I would have
egr excessive flow. Hope someone can help me with this problem. Thankyou.
I had the same thing on an 02 and found the EGR tube from the manifold the EGR was stopped up. The tube has an orifice between the 2 sampling hoses. Replaced the tube and no code.
__________________
WV Chapter Member
2002 Escape
1999 F250 4x4 SD Crew 7.3 "The Beast"
1999 Mercury Sable
1982 F250 4x4 Known as BullDog! wilh a 300 l6, Offy "C", Holley 390 CFM
1960 Austin Healy Sprite MK I (Bug-Eye)
