Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 04-28-2008, 10:08 AM
techsuphunt is starting off with a positive reputation.
2001 escape p0402 code need help
I have a 2001 ford escape 3.0 v6 with the emissions light on, I checked the code came up with p0402 egr flow excessive. I have replaced the egr valve,
egr valve solenoid and the egr pressure sensor. I reset the light after I
replaced each item, and the light comes back on. I checked all my vacuum lines they checked good. And if I had a leak I dont think that I would have
egr excessive flow. Hope someone can help me with this problem. Thankyou.
  #2 (permalink)
Old 04-30-2008, 07:08 PM
Pejeeper is starting off with a positive reputation.
DPFE sensor, search for it. Easy fix.
  #3 (permalink)
Old 04-30-2008, 07:46 PM
Thankyou but I already replaced that pressure sensor, DPFE.
  #4 (permalink)
Old 04-30-2008, 09:23 PM
5_labsownus's Avatar
Real Trucks No Sparkplugs
5_labsownus is gaining momentum as a positive member of FTE.5_labsownus is gaining momentum as a positive member of FTE.
I had the same thing on an 02 and found the EGR tube from the manifold the EGR was stopped up. The tube has an orifice between the 2 sampling hoses. Replaced the tube and no code.
__________________
WV Chapter Member
2002 Escape
1999 F250 4x4 SD Crew 7.3 "The Beast"
1999 Mercury Sable
1982 F250 4x4 Known as BullDog! wilh a 300 l6, Offy "C", Holley 390 CFM
1960 Austin Healy Sprite MK I (Bug-Eye)
  #5 (permalink)
Old 05-01-2008, 10:28 PM
I checked all vacuum lines none are plugged up or leaking.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
