It's best to cut a hole in the firewall and run a hose from the air cleaner into the cab. You have a snorkel, and it doesn't look stupid being outside the cab.
__________________
--Max
1981 F-100
(former Wisconsin Public Service Truck)
Uncle stosh: i dont think the point of a snorkle is so that the carb can be submerged, its so that water being spashed at the
aircleaner isnt being pulled in. I think its usefull on any mud trucks
I wonder what would make the best hose ? ... Dryer vent? ... Flexible exhaust? ... PVC? ...
__________________
Current:
1986 Ford F250 XL Exploder--4x4, 6.9 NA IDI, C6
.. body by Rusty Crunchy
the best hose is heat riser hose. U can get it at autoparts stores. its meant to go between the the heat riser on the exhaust to the opening in the aircleaner
Have you tried a Jeep forum? Those guys add snorkels quite often. They probably have a solution to the distributor problem also. There's a few of those Saturday morning off-road shows that have had video of those things driving up to their windshields in water.
You are going to need a lot of other things first before you have to worry about a snorkel. Things like extended axle vents, electric fan, sealing the distributor, etc.
Or, maybe you just want to look "cool" with a big tube running up the side of your A pillar.........
__________________ I shop in the salvage yard.
"They are not Stepsides. They are Flaresides. If you want a stepside, buy a Chevy."
It's all moot unless you have a diesel. Water will get to the dizzy before the carb. Thought of this myself, and that's the reason I never did it.
F250 6.9l IDI ... ... What if you ran it thru and down the inside of the firewall, along the floorboard and under the seat? ... Usually some room under there if you wanted to put a filter on the end of the hose ... Stubbing it out under the dash might be better but there is usually not much room there ...
__________________
Current:
