Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 05-06-2008, 08:22 PM
3Mike6 is gaining momentum as a positive member of FTE.3Mike6 is gaining momentum as a positive member of FTE.
Hi Eric, I'm only here to inform on my experience as well...but could lend some insight for those that may need information.
I could talk about this for hours...but it'd sound like a pi$$ing match, if you really think a mechanical fan is best for you...go for it...for anyone else reading, I'd say do some research, check CFM rating..then com[are to how many CFM's a mechanical fan can draw at any given RPM.
Unfortunately the Captain is not with me tonight, but I'm thinking there's a Coors in my future somewhere!
__________________
  #17 (permalink)
Old 05-07-2008, 03:51 PM
EricJ is starting off with a positive reputation.
No pissin' here Mike, your the one drinking beers, you'd definately win that one. But back on track, I don't have an issue with the effectiveness of an electric fan, I just never saw the need or the desire to make the system more complicated. If you have a situation where an engine driven fan wont cool your engine then by all means explore other avenues. But other than trying to squeeze every last hp out of her, I never saw the need.
And you really have to try the Captains private stock
  #18 (permalink)
Old 05-08-2008, 05:04 PM
41inWV's Avatar
41inWV is starting off with a positive reputation.
To perhaps try to close the loop on the 'engine driven' fan vs. an Electric fan I only speak from experience on my PERSONAL street Rods. My '34 chevy sedan has a 350 small block set way down between the frame rails. The stock three piece hood lends itself to trapping all the ambient heat under the hood with very little avenue to expel the heat. I had intermittent over heating issue untill I installed a SHROUDED electric fan. An unshrouded electric did no good.
My preference on the '41 is to go with an engine fan, which since I've put a '48-'53 style cam and electronic distributor/ignition would require me to switch my alternator bracket to allow the attachment of the later style fan support and utilize the second groove of my crank pulley to drive the fan.
For now it will be strictly a cost consideration, the electric fan setup I would install will run around 250.00 I'll investigate the more original setup and then decide.
Thanks for all the interest and input.
__________________
Steve
WV Chapter Member
1941 Ford 1/2 Ton Flathead
1934 Chebby Sedan
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
