Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-23-2001, 12:40 PM
GendoIkari69 is starting off with a positive reputation.
351W or 351W w/ EGR
I have an 86 Bronco with 351W 5.8L. What is the easiest way to identify whether is is just a 351W or 351W w/ EGR. I was looking around on Edelbrock's site and noticed that it was seperated into these two. I'm just getting into messing with my bronco and an looking at different parts.
__________________
1986 Ford Bronco
351W HO bored .030 over
Crower 15935 cam
MSD dist, coil & ignition
Holley Truck Avenger Carb
Custom guage pod hopefully coming soon!
  #2 (permalink)
Old 09-23-2001, 05:08 PM
rc351w is starting off with a positive reputation.
351W or 351W w/ EGR
Most likely that it has EGR if its the origional motor in the truck. Look at the centerdome behind the carb, there should be a large vacuum pot sticking up at an angle. If its there, than it has EGR.
RCC
__________________
Life is a long lesson.
The more you learn, the more
you realise your not as wise
as you think. RCC
  #3 (permalink)
Old 10-01-2001, 06:41 PM
cbwarrior's Avatar
cbwarrior is starting off with a positive reputation.
351W or 351W w/ EGR
Is it possible to remove the EGR plate from under the carb and run it that way?
88 F-150 4X4 XLT Lariat w/5.0 EFI 5 spd (DAILY DRIVER)
86 Ranger 2WD w/2.3L EFI 5 spd to be 351W 4bbl C4 (NEW TOY- DETAILS WHEN FINISHED)
85 Old Cutlass Supreme 350/TH350 Holley 4160,Edelbrock Performer intake, el-cheapo headers, General Kinetics 270H series cam, 15.588 best 1/4 mile with original 10 bolt 2.41 gears (OLD TOY)
__________________
88 Ranger S-cab 2wd 2.3T 5spd Volvo FMIC 8UA IHI
88 F150 4X4 5.0L 5spd Short Bed (For Sale)
85 Cutlass Supreme w/ '73 455/TH350
  #4 (permalink)
Old 10-12-2001, 07:33 PM
351W or 351W w/ EGR
It is on a carbed 302 if you have a none EGR spacer, but the 351W's generally had an aluminum centerdome with the EGR built in.
RCC
__________________
as you think. RCC
  #5 (permalink)
Old 10-14-2001, 11:44 PM
slimersoup is starting off with a positive reputation.
351W or 351W w/ EGR
The non-EGR intake will fit on a motor that came with EGR. Simple as bolting the carb onto the new manifold, without the EGR plate underneath it. I put a Performer RPM non-EGR on my 351w and nothing went together any differently. Mostly a question as to whether your state allows you to mess with the emissions of your engine.
  #6 (permalink)
Old 10-16-2001, 10:53 AM
tamarackstyle is starting off with a positive reputation.
351W or 351W w/ EGR
ive got 351W with egr. I replaced egr spacer with aluminum spacer(open plenum)and lost all peformance. ordered a new spacer (4 hole plenum). in meantime took egr spacer, seperated egr from nut(part of egr)that screws into spacer and closed off the hole left from the egr(1/4") with a nut and bolt. worked perfect. got the new spacer in and threw that on and it worked perfect too. the only difference is one was nice to look at.
  #7 (permalink)
Old 10-20-2001, 11:08 PM
cbwarrior's Avatar
351W or 351W w/ EGR
[font size="1" color="#FF0000"]LAST EDITED ON 20-Oct-01 AT 11:10*PM (EST)[/font][p]Mine has the EGR plate.Do you actually need the spacer? I'm trying to reduce the heighth of my engine for my Ranger.The way I see it is as long as the holes to the EGR system are blocked by the baseplate of the carb, you don't need a spacer.Is this true thinking?
By the way, what do you mean about the 'centerdome'?
__________________
  #8 (permalink)
Old 10-23-2001, 09:34 PM
351W or 351W w/ EGR
You will still need some sort of a spacer, but you could probably find something thinner than the EGR plate. There is not enough room for the throttle arm to move if you place the carb on a Ford EGR intake without the EGR plate.
  #9 (permalink)
Old 10-24-2001, 11:42 AM
DannyP is starting off with a positive reputation.
351W or 351W w/ EGR
__________________
'93 F350 4x4 SRW reg cab, ZF 5sp, 5.9 Cummins, BHAF, 3.55s, 4" exhaust, gauges galore, 12k Warn winch, hydroboost
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
