Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-23-2001, 03:15 PM
boone6978 is starting off with a positive reputation.
302 roller rocker heads on a 289
i recently acquired a pair of 302 heads from a 86 f-150 will they work good on a 289 block from 67? just wondering. Dan
  #2 (permalink)
Old 10-24-2001, 10:22 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE.
Compare the chambers of the 86 and the 67. You will probably see the later heads have bigger chambers which means lower compression ratio.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 10-26-2001, 12:02 AM
Rosati's Avatar
Rosati is starting off with a positive reputation.
You can use the 86 heads on your 67 block. Ypur compression will be lower but you can raise that with flat top or domed pistons. Your 302 heads will have a 69cc chamber and your 67 289 heads are 54.5cc chambers. Before tossing the 289's check the rocker area for screw in studs. If you have them and a set of double dots over the "289" you may have a set of factory hi po heads made from 63-67 only. These have a casting number of C4OE-B, C5OE-A, or C5AE-E (they never used rail style rockers on these).
Krosati
Visit my homepage at ClubFTE
[link:www.clubfte.com/users/krosati/|My Homepage]
__________________
Rosati
64 F100 with a few upgrades.
  #4 (permalink)
Old 10-28-2001, 12:04 AM
Rosati's Avatar
__________________
Rosati
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
