Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-28-2008, 01:11 AM
themoparkid's Avatar
themoparkid is starting off with a positive reputation.
electric cooling fans
I was thinking about taking out the crappy clutch cooling fan and replacing it with an electric fan. Jeg's has some basic relay kits with a switch to turn it on manually. Has anyone ever done this mod? I heard the clutch fan setup puts drag on the motor.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-28-2008, 10:04 AM
Sycostang67's Avatar
Sycostang67 has a good reputation on FTE.Sycostang67 has a good reputation on FTE.
The clutch fan actually creates less drag on the motor than a fixed fan. The clutch fan spins freely for the most part and really only engages as the temps get hot. Make sure the electric fan you get will flow enough air to keep your motor cool if you are eliminating the pulley driven fan. Get the largest fan you can or a couple small ones to cover as much of the radiator as possible. A flow rate of 3000cfm or better would be best. A cheap way to do it would be to scout the salvage yards for some full-size front wheel drive cars. They have good electric fans in them. I put a 12" fan from a celica on a BB dodge as a helper and it made a huge improvement.
__________________
1985 F-250HD XLT Lariat Supercab 4X4 460/5spd with a body swap.
2000 Mustang 3.8/AT
1979 Capri 302/5spd
1967 Mustang 351W/4spd
Sounds of the stacks- http://s107.photobucket.com/albums/m...t=DSCF0270.flv
  #3 (permalink)
Old 05-04-2008, 12:50 AM
hotrod351 is starting off with a positive reputation.
i live in arizona where our temps get up to 120. i bought one of spals best fans, even got the wiring kit with the thermostat. put in place of my wifes stock flex fan in her 70 mustang, waist of time. i then bought there pusher blade and installed the fan in front of my radiator of my jeep. i still have a aluminum bladed fan on my jeep and with it running and then i switch on the electric fan and what a difference, its great, but thats as a pusher working with a fixed bladed fan. what i did on my chevy was go to the junk yard and got a , believe, 7 or 8 bladed fan and attached it to my fan clutch, major difference.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
