Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-28-2008, 12:20 AM
goodB0Y is starting off with a positive reputation.
wrong engine oil...oops!
hey everybody...I did an oil change today and realized that I put castroll 10-40 instead of 15-40...the container says nothing about being good for Diesel's...anyone have any ideas as to if this oil is ok...
thanxs,
Corey
p.s. 1991 7.3 idi
  #2 (permalink)
Old 04-28-2008, 12:43 AM
Dodge/Cummins is starting off with a positive reputation.
Some oil is better than no oil.
BUT drain it and put in 15W40, I'm kind of cheap so I would probably pull the filter, drain it and put it back on.
I'd use the oil in what ever you origionally bought it for too. Just make sure and drain it into something REALLY clean. I can't imagine the little bit of 10W40 left in the filter is going to hurt anything.
I don't know for sure about your truck but some owner's manuals say you can sustitute oil in VERY low tempuratures but the HOT time of year is coming.
You aren't going to be LOSING anything so it's a no-brainer.
  #3 (permalink)
Old 04-28-2008, 12:57 AM
1970 Boss 302 is starting off with a positive reputation.
No you should not use gasser engine oil in a diesel engine. They are not the same oil. I believe gas engine does not have the same temp.rating as a diesel engine oil. Diesel engine oil must work harder and I believe has more additives than gas engine oil. If I am wrong I hope some one surely correct me .
  #4 (permalink)
Old 04-28-2008, 12:59 AM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
What is the API rating?
The S part of the rating is for gasoline engines.
The C part is for diesels.
CD or CE and you are good to go.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #5 (permalink)
Old 04-28-2008, 11:27 PM
royzell is starting off with a positive reputation.
'you could always put the 10-40 in your fuel tank.....
__________________
88 F-250 ext cab, 7.3, C-6, 3:55, 4WD, aftermarket modified powerstroke turbo with intercooler
84 Mercedes 300SD turbo-diesel(parts car also)
93 Honda Accord
77 Chev Class C Motorhome
and other rusty or rugged parts vehicles...
  #6 (permalink)
Old 04-28-2008, 11:39 PM
1994diesel's Avatar
1994diesel is starting off with a positive reputation.
Quote:
haha, there you go! its a win-win situation.
__________________
94 F-250 Turbo Diesel, 7.3L IDI, E4od, 4x4, long bed, ext cab, pyrometer, ATS boost gauge, pump turned up 2 flats, Straight pipe
93 F-250, 7.3L IDI, E4OD, 4X4, long bed, ext cab, straight pipe... almost.
  #7 (permalink)
Old 05-03-2008, 11:41 AM
thanxs for the replys... and thanx dave for the info but I threw out the container... think I'll just dump the oil and call it an engine flush, an expensive engine flush the oil cost me like 40 bucks!!! Dam that buy's alott of beer!
Corey
  #8 (permalink)
Old 05-03-2008, 07:17 PM
snubber is starting off with a positive reputation.
Maybe this can help
http://www.castrol.com/castrol/LubesSelector.do
Or call their helpline. Some guys over here use 10w30 all year.
__________________
Ford F 250 XLT Lariat 7,3 Diesel 1989, ex. cab. Long bed. 4wd. C6Aut. 4.10 diff
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
