Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-18-2001, 09:52 PM
wisnowman is starting off with a positive reputation.
what are a good reseanably priced set of heads for my 302
I have an early 70's 302, .030 over, flat top pistons, Edelbrock performer intake, 625 cfm Carter AFB, pretty much a stock cam (not radical), headers, turbo mufflers, 3.70 rear end ratio.
Ok, now the question I have is, what would be a good set of heads to use on this motor ? I don't want to mortgage the farm for these, possibly a good set of used heads from a wrecking yard that I can have gone over ??
Thanks !!
  #2 (permalink)
Old 10-27-2001, 11:02 PM
Rosati's Avatar
Rosati is starting off with a positive reputation.
__________________
Rosati
64 F100 with a few upgrades.
  #3 (permalink)
Old 10-28-2001, 04:15 PM
rc351w is starting off with a positive reputation.
If you can find a set of '69 or '70 351W heads (casting #: C9 or D0) they would work real nice. They have 60cc combustion chambers ,same as most early 302's, but have larger valves (1.84"I/1.54"E for the 351W and 1.78"I/1.48E for the 302's). With a die grinder and a lot of elbow grease they can be 'match' ported to flow as well as a set of Edlebrock Performer heads.
When I rebuit my 302, I used a spare set of '87 351W heads I had and 'match ported them myself. They work great even though I have only slightly higher compression than stock with flat tops due to the '87 heads having larger combustion chambers (64cc). Stay away from the mid '70's to mid 80's windsor heads because they have a 69cc combustion chamber which will really lower your CR.
RCC
__________________
Life is a long lesson.
The more you learn, the more
you realise your not as wise
as you think. RCC
  #4 (permalink)
Old 10-28-2001, 06:52 PM
Thanks for the info........I'll have to get out and see what I can find around here.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
