Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 04-27-2008, 09:49 PM
brush wagon's Avatar
brush wagon is starting off with a positive reputation.
Eaton E locker not engaging
Is anyone using the E locker in the front? Ive had mine for a couple years and has worked great but during my recent trip to the Bronco safari in Moab it started to give me problems. I checked the relay and have power all the way down but won't engage. If I can't get this working I'm thinking about going with the ox, does anyone have any experience with that one.
PS
Had a great time in Utah, recomend going at least once.
Thanx
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-28-2008, 07:26 AM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
I have had an OX in the front of mine for almost 5 years. It has worked great for me. The only problem I've had was with the early style shift mechanism.
If you have power all the way to the diff, you may have a bad solenoid or ground. How does it ground? Do you hear any clicking when you engage it?
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #3 (permalink)
Old 04-28-2008, 09:32 AM
The ground is up at the relay behind the dash, i'm not sure if there is a solenoid on the unit itself doesn't seem to have much room in the diff. the only clicking I hear is the relay, but I've never heard locker click in or out. I figure I'll pull the cover off and see if it's something simple, in about a week, when I get time. I think I probably go with the OX anyways wish I would have done that first.
Thanx
Travis
  #4 (permalink)
Old 04-28-2008, 11:03 AM
RCrawler's Avatar
Is that ground at the relay for the relay? Does the solenoid ground through the case then?
Jason
__________________
  #5 (permalink)
Old 04-28-2008, 07:18 PM
Good ?, there is 2 wires coming out of the diff going to the switch, getting ground and power. checked it with a volt meter and getting the same on both ends. I'm still not sure if there is a solenoid inside the case, I guess there would have to be?
Thanx
Travis
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
