Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-27-2008, 09:41 PM
6CylBill's Avatar
6CylBill is gaining momentum as a positive member of FTE.
Do I have a problem?
Hi again guys.
I'm not sure what's going on here. My truck is running fine; save two things.
A sudden drop in gas mileage. I just changed my fuel filter, air filter, keeping up with my oil and I'm using good gasoline. I was getting about 16MPG in town. Now I'm getting about 8.5. What in the world? I've noticed my truck is idling about 200 rpm higher than normal. I'm thinking this is linked?
I have NO idea what could be wrong. I need some help here.
Also note worthy; my driving habbits have not changed. My commute to work is not nearly as long as it used to be. It's about 3/4 of a mile from my house. Does this have something to do with it? Does engine temp affect gasoline usage??????
Could the flowmaster I just installed do this????????
Where should I look??
__________________
'94 F150 Flareside
4.9L, 4.11, No-Slip Locker
31x10.50 Dayton MT Mudders
Flowmaster 44 Series Exhaust
[-- Happiness is not something you find, but something you create. --]
\]My truck thinks she's a tractor.[/
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-27-2008, 11:51 PM
5.0Torx is starting off with a positive reputation.
IIRC, you have an efi truck. id run over to a chain parts store and ahve them scan your ecu. its free. see what codes its pullin.
and yes, when the engine is cold, it will run rich to warm up faster so that the chilly passengers can turn on the heat sooner. 3/4 of a mile is not enough time for the engine to reach operating temp, espcially if its still cold out for ya.
ride a bike?
  #3 (permalink)
Old 04-28-2008, 09:16 AM
6CylBill's Avatar
ride a bike?
IIRC? What is this?
I'll look into getting a scan. I just don't like the threat of these guys making up problems. So could part of the problem be my very short commute to work?
Thank you
__________________
'94 F150 Flareside
  #4 (permalink)
Old 04-28-2008, 10:20 AM
AbandonedBronco is starting off with a positive reputation.
IIRC (If I Recall Correctly)
Most guys at autoparts stores don't get paid commission (just by the hour), so they really could care less about making up stuff to sell more products.
As for a short commute, an engine normally gets about half of its gas mileage until it warms up, so if you don't go very far, 8.5 sounds about right. If you want to be sure, go on some longer trips and check your mileage to really tell if you have a problem.
__________________
1981 Ford Bronco 300 1bbl. 4 speed Manual w/OD. K&N air filter, EFI manifolds, 2.5" exhaust.
3.00 rear end and 2000 RPMs @ 80mph!
Boise, Idaho
  #5 (permalink)
Old 04-28-2008, 10:41 AM
6CylBill's Avatar
Thank you, that is most likely it then. I was hoping maybe that was all. Because other than work, I really don't drive anywhere else much. My longest trip is going to church, which is about 10 miles at around 55 MPH.
Thanks AB and 5.0. I'm out of here for a while!
__________________
'94 F150 Flareside
  #6 (permalink)
Old 04-28-2008, 12:54 PM
fmc400's Avatar
fmc400 has a very good reputation on FTE.fmc400 has a very good reputation on FTE.fmc400 has a very good reputation on FTE.
Bill, AB already told you this but I also believe it's due to your shorter commute. I agree with the rest.
  #7 (permalink)
Old 04-28-2008, 01:38 PM
Silver Streak is gaining momentum as a positive member of FTE.
For about 2 years I lived less than a mile from work and I never got mileage that bad. Yes, it will run rich at start up, but not rich enough to cause single digit mileage. I think it's fairly unlikely that your short drive is solely responsible for your mileage.
__________________
1990 F-150XLT Lariat Stillon the original engine with no squeaks or rattles at over 300k miles
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
13.18@104, no chip, no pulley, no nitrous
Confuscious say "Man who have no use for jackstand have promising career as jackstand".
  #8 (permalink)
Old 04-28-2008, 01:57 PM
6CylBill's Avatar
Quote:
Yeah. After thinking about it I kind of agree. Before I had this job I had another that was close - not as close, but still close. I got 15 - 16 mpg then. I'll look into the codes thing. Kind of scared of what I might find. No idea what else could be causging 8.5 mpg?
Quote:
I hope you're right
__________________
'94 F150 Flareside
  #9 (permalink)
Old 04-28-2008, 03:10 PM
johnboy427's Avatar
johnboy427 is starting off with a positive reputation.
I have a commute of .8 mi each way and after about 8 months of it I had sucessfully plugged up the cat. this resulted in an idle about 400rpms higher than normal a drop in mileage from 19-20 to about 9. I got rid of the cats and we are back at a solid 18mpg, no codes but it also had some off idle hesitation problems.
-Johnboy
__________________
-1979 F-250 4X4 400 4spd
-1967 Mercury Comet Sports Coupe
  #10 (permalink)
Old 04-28-2008, 05:38 PM
6CylBill's Avatar
Quote:
-Johnboy
Sounds like it.
So if I pull codes, will they tell me exactly what the problem is? For example, if it's a plugged cat, will I know? I thought I would lose power with a plugged cat, though. My truck seems to be driving the same.
__________________
'94 F150 Flareside
  #11 (permalink)
Old 04-28-2008, 05:42 PM
Most exhaust shops will check a cat for free, just take it in. Usually about 20 minutes if they're not busy.
I doubt it'll show up on an engine code though.
__________________
Boise, Idaho
  #12 (permalink)
Old 04-28-2008, 06:08 PM
How does it run? If the cat is plugged up enough to hurt your mileage it will definitely cause a noticable loss of power.
__________________
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
  #13 (permalink)
Old 04-28-2008, 06:10 PM
6CylBill's Avatar
That's the thing, SS. It's running fine just like normal. Starts good, accelerates good, idles good. The only things I've noticed is the obvious loss of mileage and a 200 rpm higher than normal idle - and the higher idle doesn't happen all the time.
I guess I'll just have to bring my truck into a shop to pull some codes. 8.5 mpg just isn't going to cut it.
__________________
'94 F150 Flareside
  #14 (permalink)
Old 04-28-2008, 06:11 PM
6CylBill's Avatar
How would they do that? Computer, obviously??
__________________
'94 F150 Flareside
  #15 (permalink)
Old 04-28-2008, 09:42 PM
optikal illushun's Avatar
optikal illushun is starting off with a positive reputation.
backpressure test...
its actually ur trucks way of rejecting the flowmaster u installed LOL j/k
__________________
93 F150 XLT 4x4
Modded 300/Built E4OD
RC 2 1/2" lift
33 ProComp MTs
15x8 AR 147's
Crane 503905 cam
Crane coil
Taylor wires
Hedmen headers
1988 F350 Custom 4x4
7.3 IDI/ZF
RayWel lid w/ Opti'ized ram air
"G" codes
True 2 1/4" duals w/ packs
315/75/16 ProComp Xtreme ATs
16x8 White waggies
Alpine/Infinity stereo
3G soon
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
