Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-27-2008, 08:40 PM
6.9ford84(smoker) is starting off with a positive reputation.
Post fast idle 6.9
Hi i've got a 84 f250 6.9 diesel and the fast idle doent idle fast long enough. I want to put a toggle switch on so i can keep it idleing longer.... how do u do that, my dads 83 had one when we bought it and i wanted one for my truck. pleas any help will be welcomed
  #2 (permalink)
Old 04-27-2008, 08:58 PM
dazedandconfused's Avatar
dazedandconfused is starting off with a positive reputation.
I use to do my trucks the cheap way with a piece of wood cut to fit the RPM you wanted because it was cheap and easy.lol
__________________
1986 Ford F-250 straight axle restore under way.
  #3 (permalink)
Old 04-27-2008, 09:30 PM
rmalottwtes30's Avatar
rmalottwtes30 is starting off with a positive reputation.
Why do you want it to fast idle longer?
The fast idle is controlled by temperature. I'm not sure how and if you can adjust the time frame the fast idle is activated but you can control the RPM it is when the fast idle is activated.
Also you may get more replies by putting this in the pre-power stroke forum just a few forums down.
__________________
Ryan
1985 F-250
6.9 Diesel
Hypermax 3.5 exhaust
Injector Pump turned 1 flat
Homemade ram air intake
http://s32.photobucket.com/albums/d5...Ford%20Diesel/
  #4 (permalink)
Old 04-27-2008, 09:31 PM
Cylinder wash down is one reason if you idle for extended periods of time.
__________________
  #5 (permalink)
Old 04-27-2008, 09:51 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE.
Look at the top front of engine at the throttle linkage. There is a solenoid there that kicks the throttle open. You could hot wire this solenoid, but if you do, I would disconnect the original wiring. If you just tap into the original wiring, then besides the idle speed, you will also be back feeding a wire to the injection pump that advances the timing. You probably don't want this for extended periods.
Also, as with most throttle kicker solenoids, once you activate it, it does not have enough power to open the throttle, but it does have enough to hold it open, so you have to push the throttle open a little bit after you hit the switch.
__________________
Dave F
1989 F250 XLT Diesel
  #6 (permalink)
Old 04-28-2008, 05:44 PM
ok but my dads old 83 had a toggle switch allong the sterring wheel that u switched up and would idle fast all day if u left it on i was currious if anyone had something like this. my truck idles fast enough but not long enough.... any help is thanked
  #7 (permalink)
Old 04-28-2008, 09:41 PM
Franklin2's Avatar
That's what I was talking about in my previous post. Mount a switch, and run the wire from the switch to the throttle kicker solenoid on the throttle linkage.
__________________
Dave F
  #8 (permalink)
Old 04-29-2008, 04:31 PM
ok then i just need to run to the toggle. ok thanks Franklin2
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
