Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-02-2001, 04:07 PM
saxtonj is starting off with a positive reputation.
302 Timing and Firing Order
I just bought a long block to put in my '71 Sport Custom. It supposedly has an "H.O." Mustang cam in it. The mechanic said to use the 351 firing order to get it to run. What is the ignition timing on it and does anyone know the specs on the cam that should be in it and has anyone had experience setting up a similar engine?
Thanks,
James
  #2 (permalink)
Old 11-03-2001, 10:15 PM
Rosati's Avatar
Rosati is starting off with a positive reputation.
__________________
Rosati
64 F100 with a few upgrades.
  #3 (permalink)
Old 11-03-2001, 11:18 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE.
If you are using a carb, treat it like any other small block Ford, timing anywhere from 8 btdc to 14 btdc. Make sure you use the flywheel that came with the engine or a late model flywheel to match the engine. Approx 1982 and later used different balance flywheels/flexplates.
__________________
Dave F
1989 F250 XLT Diesel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
