Installed starter button
Old 04-27-2008, 06:11 PM
77460ford's Avatar
77460ford
77460ford is offline
I saw this thread pop up a couple times and did some looking around. The one button I liked the look of was in the Honda S2000. A quick search found the following thread that was excellent for wiring and listing parts:
revlimiter.net - S2000 Start Button
A trip to the Honda dealer, NAPA and the local computer store had all the parts collected. Pop out the cig lighter and massage the opening a little, a little wiring and done. You still need the key for power but the button does the starting. It even kept the safety feature of only starting in park.
Do you really need this, of course not. But I like it
Old 04-27-2008, 06:18 PM
tankrsc's Avatar
tankrsc
tankrsc is offline
That looks cool do you have a pic that gets more of the dash? Does it look like it should be there like it does close up?
Old 04-27-2008, 06:23 PM
77460ford's Avatar
77460ford
This shows a little farther back with the lighter still in place:
Old 04-27-2008, 06:32 PM
77460ford's Avatar
77460ford
Here's the before, the after will take a couple days since the truck is still at the shop getting ready for the season.
Old 04-27-2008, 06:48 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
no offense, but that is one messy looking dash
Old 04-27-2008, 06:49 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
I like the gauge install next to the glovebox. are they angled towards the driver? they look like they are in the pic.
Old 04-27-2008, 06:51 PM
brentleedragon's Avatar
brentleedragon
brentleedragon is offline
77460ford I always love looking at your interior pics because their awesome, I love what you've done
Old 04-27-2008, 07:03 PM
rsalter66's Avatar
rsalter66
rsalter66 is offline
Mine will be that cool one day,
good job and I dont think its a messy looking dash at all,
I like it
Old 04-27-2008, 07:13 PM
tankrsc's Avatar
tankrsc
tankrsc is offline
Looks pretty cool to me
Old 04-27-2008, 07:46 PM
highboy250's Avatar
highboy250
highboy250 is offline
Looks pretty sweet, love the truck too man.
Old 04-27-2008, 08:26 PM
77460ford's Avatar
77460ford
No offense taken, one persons taste does not always capture another. That's what I like about this site, from straight resto to all out drag trucks and everything in between.
The fuel & nitrous pressure gauges use the Autometer rings that angle them toward the driver. They work great and make it easy to read.
I've got a cab in storage, as I do different things I find what I like and what I want to change. Within a year or two I'll strip the present truck and swap the running gear and use the new body. Only time and money slowing me down
Old 04-27-2008, 09:01 PM
rsalter66's Avatar
rsalter66
Not to hi-jack 77460ford, but I have a few questions for ya
do you run the stock pump with that hydrolic pump for your oil?
also could you tell me what you used again?
I am going to start looking for one
and last but not least, what do they call that fiberglass piece behind your cab?
I love that, you have the baddest truck I have ever seen
Old 04-27-2008, 09:24 PM
psquare7575's Avatar
psquare7575
psquare7575 is offline
x2..
There are gauges literally all over the place.
And in all honesty, if you left the key"start" hooked up, how often do you remember your button?
Old 04-28-2008, 05:49 AM
77460ford's Avatar
77460ford
The key is required for power, not start. You can turn the key to the start position but nothing happens because the "Start" button is wired in it's place. This means you need a key to get the truck moving.
The gauges to the lower left are moving to the dash in place of the radio, easier to see at a glance. The gauges and switches to the right of that all look after the nitrous system.
The pre-luber is a 12Vdc sealed hydraulic pump found on lawn tractors, it's plumbed into the pan and back of the block. I found mine in a buy and sell paper locally and it's been trouble free for many years. Not much work for it really.
The fiberglass rear fairing is a LUND racerback, it also has held up well to years of use and abuse .
Old 04-28-2008, 07:13 AM
RCrawler's Avatar
RCrawler
RCrawler is offline
An F-18 could be considered to have messy dash too, but I would trade a ******** for a test drive (fly) in one. The same could be said for 77460ford's truck.
If I had a BB on nitrous, I would want plenty of gauges to keep tabs on it. And redundant gauges to keep an eye on the regular gauges should they fail.
And switches... Lots of switches... Neatly arranged switches.
Now just figure out the technology of those factory keyless ignition systems and do away with the old keyswitch altogether. That would finish it off.
Jason
Quick Reply: Installed starter button
