Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-25-2001, 03:48 PM
Donate52 is starting off with a positive reputation.
if you know anything about 5.0's please read!
i was considering rebuilding my engine and then adding a couple of performance parts, but the costs of doing that are really high from the quotes ive gotten. turns out, for the same price i can buy a gt-40 crate engine from summit (complete with all internals, just need to add induction and exhaust). heres my question, i know that stangs and trucks have different intake manifolds, so will a truck intake fit this engine? what about the exhaust, will truck headers fit? or will i need mustang headers? thanks for any help!!!
__________________
1989 F-150 XLT
  #2 (permalink)
Old 10-28-2001, 04:00 PM
rc351w is starting off with a positive reputation.
Correct me if I'm wrong, but I beleive that the 'GT-40" heads have stock location intake and exhuast ports which means that they can be used with all stoke induction and exhuast parts, truck OR car.
One other point you may want to consider when buying a crate motor is the cam. Depending on your rear axle ratio and tire size, the cam may not suit your specific application. Long duration cams give higher horsepower but at the price of putting the powerband in a higher RPM range. If the cam puts the powerband above your normal RPM range you'll be sadly dissapointed with your new engine, it will always feel as though it's gutless. For most truck applications I would keep the cam duration below 215 degrees @ 0.050". This will give you good low end torque and nice mid range power.
RCC
__________________
Life is a long lesson.
The more you learn, the more
you realise your not as wise
as you think. RCC
  #3 (permalink)
Old 10-29-2001, 10:40 AM
thanks for the info! i never knew that aout the cams, i dont know too much about cam lift or duration, thanks for the tip!
__________________
1989 F-150 XLT
  #4 (permalink)
Old 10-30-2001, 02:16 PM
how about if i just add a carb to the crate engine, then add a cam with some nice low end power (ive been told to look for a cam with intake duration between 190 to 215 degrees). then in the future i could do home head work, or just buy a good set of aluminum heads. what do you guys think?
__________________
1989 F-150 XLT
  #5 (permalink)
Old 10-31-2001, 09:07 PM
Keep in mind that you need to match the cam to both the desired RPM range as well as the Compression ratio of the engine. If the CR is less then 9:1 you can go with about 204 duration and under, if you are over 9:1 CR you need to go with and longer duration cam ( up to 215). This is because with higher CR engines, a short duration cam will cause cylinder pressures high enough to blow head gaskets or worse. Go to:
http://www.cranecams.com/master/apps/ford21.htm
for some idea as to what I mean.
As for heads, cast iron are better for the low end torque needed in an everyday truck motor although a good porting/polishing job won't hurt and that's something you could probably do yourself.
Aluminum heads are great for high end power but won't hold the heat needed for the good low end torque.
RCC
__________________
as you think. RCC
  #6 (permalink)
Old 11-08-2001, 04:18 PM
torp is starting off with a positive reputation.
You really think a rebuild of your mill will go as much as a gt-40 crate motor? I have my rebuild pegged at about $1100. That gets me a donor long block, a rebuild, new cam, intake, carb and headers. I will be doing the most of the work myself of course, except for the machine work.
torp
84-XCAB-2X4-302
  #7 (permalink)
Old 11-09-2001, 04:01 PM
horsepuller's Avatar
horsepuller has a brilliant future horsepuller has a brilliant future horsepuller has a brilliant future horsepuller has a brilliant future horsepuller has a brilliant future horsepuller has a brilliant future horsepuller has a brilliant future horsepuller has a brilliant future horsepuller has a brilliant future horsepuller has a brilliant future horsepuller has a brilliant future
__________________
Scott
FTE Moderator
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
