Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-27-2008, 05:34 PM
heartnurse73 is starting off with a positive reputation.
no fuel from IP
hey folks i just bought a 1990 f-350 with a 7.3, ran home fine went to restart and wouldnt. after thuro investigation i have fuel all the way up thru the fuel line into the IP. but notta coming out on #1 line. when i turn the key on i hear the idle solenoids working, cant figure it out.
as a side note the truck was almost outta fuel when it came home and i wondered if air locked but i didnt get any air from the fuel line. i did put fuel in it.
Thanx Jay
  #2 (permalink)
Old 04-27-2008, 06:53 PM
FORD MEGA CAB!!! is starting off with a positive reputation.
I posted and didn't read your whole post very well and missed the last sentence that said you put fuel in it, so i deleted mine since you already put fuel in the tank. Sorry
  #3 (permalink)
Old 04-27-2008, 08:13 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
heartnurse73,
Welcome to FTE and the IDI diesel forum.
If you did suck in some air, it takes a bit of bleeding and cranking to get it started again.
Please be careful cranking the starter, 20 seconds max crank time then at least 2 minutes cool time before cranking again.
Starters are very easy to overheat, and expensive to replace.
You do have fuel to the IP now?
Loosen a couple injection lines, then try starting again, with the throttle held on the floor.
When you start seeing fuel seep out of the injection lines, retighten the line nuts.
Best to keep the tank over 1/4 tank, such a pain to get a diesel started after running out of fuel.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #4 (permalink)
Old 04-27-2008, 08:20 PM
bigredtruckmi's Avatar
Farmer and proud of it
bigredtruckmi is gaining momentum as a positive member of FTE. bigredtruckmi is gaining momentum as a positive member of FTE.
Also check to see if the wire is on the fuel shutoff valve on the IP.
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
