Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-27-2008, 02:49 PM
towerace81 is starting off with a positive reputation.
Dealer Flashed Over SCT Program, HELP!
I work on my uncles 04 f-350 King Ranch PSD when he needs it. Mostly non dealer stuff, 5" MBRP turbo back with cat delete, Volant Ram Air intake, Superchips Flashpaq and so on. My uncle is not very savy when it comes to vehicles, but he decided to de-tune the truck back to stock with the SCT so he could take the truck to the thieves at the dealership to have 60,000 mile service done. he only thought he de-programed it, but actually left performance mode installed. long story short, the dealership flashed over the SCT performance program, now truck misses, smokes, lots of lag, no power! Help, what can be done to resolve this problem?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-27-2008, 03:02 PM
cartmanea is gaining momentum as a positive member of FTE.
If the dealer flashed correctly it should have overwritten everything the SCT put on so it shouldn't be an issue. Sounds to me like they screwed up the reflash. Have you tried disconnecting the battery and resetting everything?
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Donahoe Racing springs, Bilstein shocks, 35" tires
- Off Road Tech winch bumper, powdercoated white
- SCT Xcal2 with Spartan tunes (ASE)
  #3 (permalink)
Old 04-27-2008, 03:06 PM
yep, had bats out yesterday for about 8hrs while i was going threw EGR to see if that was part of the problem.
  #4 (permalink)
Old 04-27-2008, 04:10 PM
doubledee715's Avatar
doubledee715 is starting off with a positive reputation.
take the performance tune out. Does SCT also stand for superchips flashpaq or is he using an xcal?
__________________
David, 2003 f250 6.0 cc sb Centennial Edition, Dieselsite coolant filter, afe stage 2 w/pg7, ejf1000 edge juice w/attitude replaced w/innovative tuned xcal, blocked off egr cooler, Quadzilla Commander w/pillar mount, ARP studs, ITP RR, 05 accufab elbow, 4" tb, pic
  #5 (permalink)
Old 04-27-2008, 05:28 PM
I removed the performance tune, changing it back to stock. The truck runs even worse now, shifting is eratic, sometime very stiff, othertimes it feels like its slipping. Truck has a very noticable misfire just off idle through about 60% throttle after it gets to opp temp.
  #6 (permalink)
Old 04-27-2008, 08:30 PM
bigredtruckmi's Avatar
Farmer and proud of it
bigredtruckmi is gaining momentum as a positive member of FTE.bigredtruckmi is gaining momentum as a positive member of FTE.
Take it back to dealer for another flash . the program didn't work the first time.
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #7 (permalink)
Take it back to the dealer that flashed it and tell them they screwed something up.
__________________
  #8 (permalink)
Old 04-27-2008, 09:08 PM
ORRRR take it to a different dealer that actually knows how to flash the computers instead of going back to the one that screwed your rig up the first time.
__________________
  #9 (permalink)
Old 04-27-2008, 09:11 PM
My thoughts on this. Is why pay twice for the same job? Yes they messed it up and should make good on it. If they can't fix it the second time request refund and take it to other dealer.
__________________
B5 soydiesel user
Sirius radio
  #10 (permalink)
Old 04-27-2008, 09:16 PM
who said anything about paying twice? Flashes are free under warranty.
__________________
  #11 (permalink)
Old 04-27-2008, 09:18 PM
Thought there was a $100 deductible on engine work. When over 36K
__________________
B5 soydiesel user
Sirius radio
  #12 (permalink)
Old 04-27-2008, 09:42 PM
scottman70 is starting off with a positive reputation.
Quote:
Yes they do charge $100 for warranty work that's done beyond the 3/36k warranty....
  #13 (permalink)
Old 04-27-2008, 09:56 PM
4x4Mark is starting off with a positive reputation.
Quote:
Trying to return it to "stock" with a saved OEM flash, after the dealer updated the truck with a newer flash, will really mess them up as you're then mixing-matching calibrations. I don't believe your saving the entire calibration to the SCT when your first save it.
Once the dealer updates your calibration level, that is your new baseline. You need new versions of your tunes as well.
Don't forget to unlock your SCT when you get the new flash in and working properly, and then save that to the SCT.
Mark
__________________
2004 White F350 XLT, CC, SB, 4x4, 6.0L Auto, 3.73LS, Camper Pkg, Skid Pkg, Edge 2" Mini Spring Pack, Bilsteins, MBRP exhaust, Coolant Filter, FluidAmpr, Elite Regulated Return (55 psi), Airdog
Built: 11/03/03
  #14 (permalink)
Old 04-27-2008, 10:56 PM
Thanks for all the input guys, I will get it reflashed and let everyone know how it goes.
  #15 (permalink)
Old 04-27-2008, 10:57 PM
You shouldn't have to unlock it if you get a new strategy and need new tunes. Although I am not sure if you are using an xcal or the superchips flashpaq sinnce you didn't answer my question..
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
