Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 04-27-2008, 01:29 PM
MyEx's Avatar
MyEx is starting off with a positive reputation.
2001 V-10 Upgrades
Looking for the best advice on:
Exhaust (first, Catback then will go onto Headers and Hi-Flow Cat later)
Tuner Chips
Ignition
Plugs
Pulleys
Fuel Injectors
Fuel Pump
Anything else...?
Thanks.
Currently: Stock 2001 Ford Excurson Limited 4X4
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-27-2008, 03:00 PM
dkf's Avatar
dkf dkf is online now
dkf is gaining momentum as a positive member of FTE.
What gears do you have, 3:73, 4:10 or 4:30s? A simple gear swap can put quite a bit more power to the ground. Nothing wrong with the stock ignition, injectors, fuel pump, pulleys. You won't get any gains with changing out any of those (Except maybe an underdrive pulley set IF one is made) and they only really need to be touched if your adding a supercharger or turbocharger set-up. As for plugs Motorcraft or Autolite plugs work best in the V10. How much do you want to spend on a cat-back system? You can get one from $230 on up to over $500. I have the flowmaster Force 2 w/FM70 that I modified. Banks and Magnaflow also make a very good cat-back system. For a tuner I'm running an SCT X Cal2 with a custom 87 & 91 tune from Mike at 5 Star tuning, it works great. You can see some of my mods in my gallery. I suggest checking out the V10 Modular forum, there is a lot of good info in there.
  #3 (permalink)
Old 04-27-2008, 05:28 PM
MyEx's Avatar
Quote:
dkf
I'll take a look and get back with that. As for swapping out the gears, right now I have stock size tires. I want to go up as big as possible without having to lift the suspension at all, so tire size will be an issue I'm sure. I was looking at mounting 305's (35") tires on 20" rims. I want a custom set-up, but don't want it to stand out too much.
That's good to know especially since the injection system looks as if it was just installed. I may be looking at having a Supercharger installed later on down the line.
Thanks.
I was budgeting up to $600. for a cat-back set up looking for something that I could pair up to a free flow cat and headers later on. Flowmaster is definately at the top of my list with Banks right behind. Besides getting as much power as possible, I'd love to hear my V-10 working. It already sounds sweet when I accelerate her, but I want to unleash whatever power the current system is holding back. I was thinking about a Flowmaster system with 3"+ pipes, dual exits (maybe dual mufflers if that's better for power gains) and I'd want the pipes to come out under the rear bumpers with dual tips on the ends (similar to a Flowmaster set up I had for my 84' Trans Am).
I've been listening to exhaust clips and Youtube clips of exhaust systems and Flowmaster consistently gets my blood running. Of course, more important than disturbing the peace to me is power.
I got on there right after I posted this.
I'll definately check out your set up.
I'll be posting pics up soon.
Thanks.
  #4 (permalink)
Old 04-30-2008, 09:12 AM
halerazor is starting off with a positive reputation.
crane cams makes camshafts for the v10
  #5 (permalink)
Old 04-30-2008, 04:35 PM
meanv10's Avatar
meanv10 is starting off with a positive reputation.
If your going to go the blow'n route, no onw makes a positive displacment supercharger for the v10, the only company that still makes a citrifical that i know of is Vortech
Vortech Engineering: Viewing product: 1999-2003 Ford F-250, F-350, Super Duty, Excursion Supercharging Systems
DFK is right, if you want more power do gears, lot less than a supercharger,
air filters and exhaust will only get you so far.
__________________
03 F350 v10
Kb supercharger
Autometer gauges
35" Baja Mtzs
  #6 (permalink)
Old 04-30-2008, 05:50 PM
MyEx's Avatar
Thanks.
I want to go with bigger tires (of course) than stock.
I know that gearing will be affected by tire size. I'd be content with 35"s on 20"s. What gearing do you suggest?
  #7 (permalink)
Old 04-30-2008, 05:55 PM
dkf's Avatar
Quote:
You will want to maintain a 4:30 gearing with the 35" tires for best performance. Heres a link to the tire calculator. Automotive Calculators offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com 4:56 or 4:88 gears will be great for 35" tires, the V10 has no problem revving.
Heres a link to the recent thread down in the V10 forum on the exhaust I have on my truck currently. There is a sound clip in the thread as well.http://www.ford-trucks.com/forums/73...-fm70-mod.html $600 will get you a good cat-back or custom system. I recommend making shure you get mandrel bent tubing if you get a system fabbed at a local exhaust shop.
  #8 (permalink)
Old 04-30-2008, 05:58 PM
meanv10's Avatar
depends, what gears do you have right now? just right now you have a say a 30 inch tire so if you have 3.73 gears and want to to 35's then the math is. (35/30)*3.73= 4.351, so then you have to fond the next available size witch is 4.30, personally the change from stock tires to 35's wasn't as bad as i thought, and the only reason i would still do it is for a faster 0-60 otherwise i have no complaints.
__________________
03 F350 v10
Kb supercharger
Autometer gauges
35" Baja Mtzs
  #9 (permalink)
Old 04-30-2008, 05:59 PM
meanv10's Avatar
Man right after i got done typing all that and DFK beats me to it, fricken A
__________________
03 F350 v10
Kb supercharger
Autometer gauges
35" Baja Mtzs
  #10 (permalink)
Old 04-30-2008, 06:30 PM
MyEx's Avatar
Thanks a lot D.
I think I'm going to go with just 305's (32.7") to keep the stock ride height only lifting the rear a bit (maybe with blocks).
If anything, I'll want to soften the straight ride and definately tighten the suspension (sway bars).
  #11 (permalink)
Old 04-30-2008, 06:43 PM
MyEx's Avatar
It looks like it's going to be 4.30's for me.
I'm going to go with the 305's.
All I know is that when I plunge that accelerator, I want that truck to feel as if it's been kicked in the rear by Godzilla.
I want that nice controlled feel that the deeper I depress the pedal, the faster she goes. If I floor it, I want it to launch me into hyperspace.
The supercharger will be the last thing I do to the V10.
Freer than stock breathing (intake/exhaust), a good chip and the right gears with a good ignition (and of course good lubing & fluids).
I want to do things in steps. Simple add-ons that don't affect reliability.
1. Cat Back, air filter, plugs, wires, fuel pump, fluids.
2. Chip, Headers, Free Flow Cat. Ignition System.
(Maybe...)
3. Supercharger, Cam Kit, Tranny Work.
  #12 (permalink)
Old 04-30-2008, 06:46 PM
MyEx's Avatar
Not for nothing, but I sure wish Ford made a new Excursion.
The Expedition EL is nice, but I'd love to own a new Excursion with the latest tech.
But, I'll be completely happy with my Ex!
  #13 (permalink)
Old 04-30-2008, 07:08 PM
dkf's Avatar
Thanks a lot D.
305s will fill out the wheel wells. I have 285/75/16 (33s) on my truck with no lift. 305s are 1" wider than 285s. I have 3:73s but am eventually going to swap to 4:30s and a truetrac in the rear, maybe even an e-locker up front, but its going to be a while. My truck moves very well with 3:73s and the mods I have on it, but I want more.
I'd like to see an Excursion put back in production in both 2-Door and 4-Door models. The Expedition EL with its IRS and 5.4l is a brain fart in my book.
As far as oil goes I switched over to Motorcraft 5-20. I was running full synthetics but the MC oil is top notch and I got tired of pissing away 3X more $$$ by using full synthetic for no difference in power, mpg or anything. I run full sythetics in the front diff, rear diff, transfer case and tranny though.
  #14 (permalink)
Old 05-04-2008, 07:41 AM
kaboom10's Avatar
kaboom10 is starting off with a positive reputation.
I'm running 4.56 w/stock 31.6 inch tires. Using the OD puts it back to about stock RPMs. I used to never use OD trying to get performance. Mike did my tunes from Home .
__________________
2002 F-150 5.4L 4wd
Amsoil filter element w/ mod air box
Baer rotors EGR Carbon Kevlar pads
Flowmaster
Kenwood
Optima battery
Livewire PRP tuned w/wideband O2
Modified 4R70 Trans(shift kit)
4.56 gears and Trutrac carrier
B.F.Goodrich Rugged Trail
Stab the throttle ain't got no bottle
  #15 (permalink)
Old 05-04-2008, 08:11 AM
MyEx's Avatar
Excellent to know (on the oil thing). I hear that a lot that Motorcraft is what should go into the Ex's over upgraded additives.
I actually saw an artist rendering of a 2 door Ex that was being considered for production and it looked a lot like a Bronco (in fact, it was going to be the new Bronco!). It was sweet!
The Exp El is a nice looking truck (especially from the front doors back), but again...I won't go backwards.
And, I love my IB Suspension! Had it on my '85 F-150 and it was bulletproof!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
