Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-27-2008, 01:45 PM
Mr. Bob's Avatar
Mr. Bob is starting off with a positive reputation.
Need ATS kit help!
I found an ATS kit locally, but its missing the snail, and the valve cover.... I have a few extra valve covers, so I dont mind making one house the CDR if I have to, but can you buy just the snail from ATS?? I sent them an Email and the reply talked about grommets and some other stuff, but nothing about the snail....
Thanks guys!
Bob
__________________
2002 F350 XLT 4X4 7.3L Auto, Reg Cab, 3.5" lift, 35" BFG ATs, 6637 Filter, 4" Exhaust with Cool Duals, 215CC Swamps Hybrids, Garrett BB Turbo with 1.15 Exhaust Housing, DP Tuner tunes, Fass fuel pump, DFA regulated return with fuel bowl delete, 6.0L IC, SS HPX, Gauges, 2005 Headlights, Grill and Mirrors.
Next: Rods!!
  #2 (permalink)
Old 04-27-2008, 03:28 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
What turbo kit is it? If its an older none wastegated setup than I doubt ATS will be any help at all. Might be worth phoning them directly and asking some on that way so they can't ignore your question.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #3 (permalink)
Old 04-28-2008, 12:48 AM
dieselhappy is starting off with a positive reputation.
Well if this helps, I just installed an old 088 ATS system non wastegated on my 7.3. I was trying to replace the intake valley grommet but ATS said they don't have parts for that anymore.
Wreckers and ebay might be your best bet. Hope this saves you some time.
  #4 (permalink)
Old 04-28-2008, 08:49 AM
gnathv is starting off with a positive reputation.
dieselhappy, Try calling ATS and asking for a G6973VP. I just bought some in March. $7.09 each.
  #5 (permalink)
Old 04-28-2008, 09:35 AM
ghunt's Avatar
ghunt is gaining momentum as a positive member of FTE.
Yeah, if it was a wastegated system, you should be able to get the turbine housing. I don't think ATS lists it separately on their website, but I'm sure if you called you could get it.
__________________
1994 F250 XLT-Reg cab, 4x4, 5 speed, 7.3 IDI Turbo, manual hubs, ATS upgrade, 4" exhaust w/Hooker MaxFlow, custom intake, pyrometer & boost gauge, turned up fuel
http://www.cardomain.com/ride/3055099
1987 Thunderbird Turbo Coupe-Lots of fun stuff to make it go fast & take corners
http://www.cardomain.com/ride/306349
  #6 (permalink)
Old 04-28-2008, 11:11 AM
thanks gnathv... I moded the down spout on the ATS casting to fit ford newer style valley grommets that come with the CDR kit. Thanks for the number though will pass it on to a buddy of mine with same problem.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
