Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-27-2008, 11:46 AM
champpydog is starting off with a positive reputation.
ac problems
I have a 2002 F250 andd I have been having this weird problem with my ac. When I accelerate the ac stops blowing out of the vents and blows up the windshield like the defroster is on, then when I slow down itgoes back to the vents. What the hell? Is it a relay or something else?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-27-2008, 12:52 PM
megawatt00's Avatar
Jaymi-Lyn says be a......
megawatt00 has a great reputation on FTE.megawatt00 has a great reputation on FTE.megawatt00 has a great reputation on FTE.megawatt00 has a great reputation on FTE.megawatt00 has a great reputation on FTE.
I'm not 100% sure on this one, but there is a possibility that the blower motor isn't running. Maybe when you slow down it's takeing the path of least of least of least resistance. This will bump you back to the top and some one else will chime in.
Oh and by the way WELCOME TO FTE!!!!!!
I also posted this reply in the super duty forum for ya.
__________________
Jim
2001 F350 4X4 DRW
Bilsteins and 4" Turbo Back MBRP Are In!!!
PAA#14
Rick, Is it April yet?
  #3 (permalink)
Old 04-27-2008, 01:09 PM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
No, it's the common vacuum leak.
Click on SEARCH and enter "+vacuum +defrost" for numerous discussions, most of which ironically, are in the Heating, Cooling, and Air Conditioning section....
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #4 (permalink)
Old 04-27-2008, 01:30 PM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant future
Quote:
Originally Posted by champpydog View Post
I have a 2002 F250 and I have been having this weird problem with my ac. When I accelerate the ac stops blowing out of the vents and blows up the windshield like the defroster is on, then when I slow down itgoes back to the vents. What the hell? Is it a relay or something else?
This could be the problem..and it sure wouldn't be the first time one failed.
F6SZ19B888AA .. Air Conditioning Vacuum Selector Valve Assy. (Motorcraft YH-1450)
MSRP: $24.46 / ftepartsguy.com price: $14.09
This valve mounts to the back side of the A/C heater control panel-this is where all the vacuum lines connect.
When you operate the lever on the control panel, the valve opens one door in the plenum chamber, and closes another.
The little darlin' is plastic and over time, it develops cracks, which causes the valve to go haywire.
One minute air is blowing out of the defroster, the next, it's blowing out somewhere else.
__________________
Bill / Retired Ford Partsman ~ 1962/1997
Part Number Research available for the following: Trucks: 1928/2002 / Cars: 1928/2000
  #5 (permalink)
Old 04-27-2008, 03:37 PM
Thanks for the input guys....I will check for vacum leaks and check the vavle assembly....I'll let you know how it works out.
  #6 (permalink)
Old 04-27-2008, 04:45 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
The engine has no vacuum when the throttle is open wide, such as during acceleration or pulling a hill. I would think your newer truck has the same setup as the older ones, with a check valve and a vacuum reservoir.
The main vacuum line for the HVAC comes from a tree on the firewall, and goes through a check valve. After the check valve, it hits a tee which branches to the vacuum tank or reservoir. The other part of the tee goes on into the firewall and is the vacuum supply for the HVAC. When you accelerate, the check valve stops the vacuum from being lost, and the HVAC uses the vacuum stored in the reservoir till things settle down and the engine has vacuum again.
__________________
Dave F
1989 F250 XLT Diesel
  #7 (permalink)
Old 04-28-2008, 01:31 AM
Ford Parts Guru
Quote:
Exactly, cars included.
For every one of those check valves, or reservoirs (we called 'em coffee cans) we sold, we sold 10 of those vacuum selector valves, that's why I suggested it.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
