Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 04-27-2008, 09:10 AM
6CylBill's Avatar
6CylBill 6CylBill is offline
1994 Ford F-150
6CylBill has a good reputation on FTE. 6CylBill has a good reputation on FTE.
Existing sound clips
Post moved to start new thread.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
Last edited by fordborn; 04-28-2008 at 11:02 PM. Reason: starting fresh-guidelines at top
  #2 (permalink)
Old 04-28-2008, 10:57 PM
fordborn's Avatar
fordborn fordborn is offline
fordborn has a great reputation on FTE. fordborn has a great reputation on FTE. fordborn has a great reputation on FTE. fordborn has a great reputation on FTE.
OK everyone this is now going to be a sticky but only for exhaust sound clips. Any conversation or general posts will be removed. This way we can keep the thread on topic and easy to look through.
When posting a sound clip please do the following.
1) Year and model of your truck.
2) List an extra mods that you have done to the truck as these could affect sound.
3) List the make and series of the exhaust you have put on.
Thanks in advance for everyones help on this thread. Now enjoy the sounds. Sorry to remove previous posts but to get this started fresh with posting rules upfront it worked out that way. Please post back up all your sounds.
__________________
1988 BII - Mad Dog
1997 F250LD - Blue Goose
  #3 (permalink)
Old 04-29-2008, 11:21 AM
6CylBill's Avatar
1994 Ford F-150
1994 F150 300I6/EFI w/ both working cats
Previous; 2.25 catback Y pipe / dual glasspacks
Now; Flowmaster Super 40
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #4 (permalink)
Old 04-29-2008, 08:40 PM
kaotikedge_111100 kaotikedge_111100 is offline
kaotikedge_111100 is starting off with a positive reputation.
Truck: 1978 F150, stock 4.9L block
Mods/exhaust: Offy dual plane intake, Motorcraft 2 barrel, hedman header 3 into 1 and 3 into 1, 2.5" pipes into dual in/out flowmaster, 2.5" tailpipe exiting in front of passenger rear tire.
Enjoy!!
truck also has 36" tires with stock 3.50 gears, still moves pretty darn good!!
__________________
http://img.photobucket.com/albums/v6...100/skills.gif
Pictures of all trucks in my gallery
1978 F150 4X4, OFFY DP, Header, Holley 390, 36" Military Wranglers, Centerforce clutch, Stockton 16.5" rims
1979 Bronco, 400, C6, NP205 ....Mint!
1979 F350 Crew Cab...restoration in progress
  #5 (permalink)
Old 05-01-2008, 08:03 PM
justin_jkj's Avatar
justin_jkj justin_jkj is offline
justin_jkj is starting off with a positive reputation.
1989 ford f150 300/6
k&n drop-in,
2 1/2" walker downpipe and a 2 3/4" straight pipe, custom 45'd (cut both pipes at 22.5 degrees) with a 4 inch tip
__________________
'89 ford f-150 300 inline 6, 5 speed, 4x2, 3.08LS
Custom exhaust, K&N Drop-in
  #6 (permalink)
Old 05-01-2008, 11:35 PM
j41385a's Avatar
j41385a j41385a is offline
j41385a is starting off with a positive reputation.
Here's my 72 F100.
__________________
1972 F100 Built 300 Inline 6.
1971 F250 5.9L Cummins 6bt.
  #7 (permalink)
Old 05-02-2008, 06:42 PM
Harte3 Harte3 is offline
Harte3 is starting off with a positive reputation.
Equipped per signature.
__________________
1983 F150 300 I6, Comp Cam 260h and lifter kit, Port/Polished head, Offy DP Manifold, Holley 4160/1848-1 465 cfm, EFI Exhaust manifolds, Walker Y Pipe to 3-Way Cat, generic Turbo Muffler, Recurved DSII, Mallory HyFire 6a & ACCEL Super Stock Coil, Taylor Spiro Pro Wires, EFI plugs.
  #8 (permalink)
Old 05-03-2008, 02:39 AM
optikal illushun's Avatar
optikal illushun optikal illushun is offline
optikal illushun is starting off with a positive reputation.
Current set up: Hedmen headers, custom 2 1/4" y pipe into a single magnaflow cat 2 1/2" out follwed up by a 4" x 20" tip exiting in front of the rear tire.
Notes: its loud, VERY loud but not much of a tone. some say it sounds like a 2 stroke diesel mixed with a sea plane taking off.
Set up: EFI manifolds with stock first cat/y pipe with 2 1/2" into a small case magnaflow dumped before the rear axle.
Notes: probably the best sound out of everything i tried. did not have as much of a ricey tone as it seems to have in the video, the mic on the camera wasnt to good.
Set up: EFI manifolds with stock first cat/y pipe with 2 1/2" pipe running just at the end of the bed and no muffler.
__________________
93 F150 XLT 4x4 Modded 300/Built E4OD/SAS-79 Dana 44-5" lift/33" ProComp MTs/15x8 AR 147's/Crane 503905 cam/Ported intakes/V8 throttle body/Hedmen headers/some kinda exhaust/Crane coil-Taylor wires/Cervini's RamAir hood/Diamond lights/Infinity-stereo
1988 F350 Custom 4x4 7.3IDI/ZF/RayWel lid w/ Opti'ized ram air/"G" codes/True 2.25" duals/315-75-16 ProComp Xtreme ATs/16x8 White waggies/Alpine-Infinity stereo
  #9 (permalink)
Old 05-18-2008, 10:10 PM
6CylBill's Avatar
1994 Ford F-150
Quote:
Originally Posted by Motorhead351 View Post
All the photobucket vidoes are showing up as photos.
Did you try clicking on the pictures?
Did a mod delete my new exhaust post? Anyway here's my new setup again.
I like it now. I still get that annoying droning noise at higher rpms. I want to add extra pipe if I ever get the time. I think by simply redirecting the noise farther away from the muffler exit it will kill some of that droning noise.
Maybe 1.5' of straight 2.25 pipe. I know the turndown kills the droning noise but also makes it quieter. I'm thinking maybe because of the bend...??? I don't know.
Any suggestions on how to kill that droning noise without hurting sound quality would be much appreciated!
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #10 (permalink)
Old 06-06-2008, 09:25 PM
6CylBill's Avatar
1994 Ford F-150
Did some more work to my exhaust. I'm through. I like it now.
Ditched the Flowmaster. I kept the high flow cat and ran pipe into a replacement tailpipe. Gave her *pop*.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #11 (permalink)
Old 06-16-2008, 12:51 PM
6CylBill's Avatar
1994 Ford F-150
Added a 31'' Cherry Bomb Muffler. I was afraid of catching the wrong police officer's attention. IMHO it sounds just as good if not better than the Flowmaster Super40 I had. Plus it's a straight through design. Wish I had known this before paying all that money for the FMS40.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #12 (permalink)
Old 06-17-2008, 09:44 PM
u been busy, sounds like me when i was trying to find that perfect sound...
just a few temp set ups as i was trying different mufflers.
Set up: Hedmen headers, custom 2 1/4" y pipe into a single magnaflow cat 2 1/2" out follwed up by a Raptor turbo and nothing after
Set up: Hedmen headers, custom 2 1/4" y pipe into a single magnaflow cat 2 1/2" out follwed up by a magnaflow SI/DO and nothing after
i have a few more of my new and probably permenant set up, just need to upload.
__________________
  #13 (permalink)
Old 06-27-2008, 01:03 PM
MatCat58 MatCat58 is offline
MatCat58 is starting off with a positive reputation.
Been reading these forums for a while since I got My truck in February realized that nobody had a clip of this muffler posted
1994 f150 xl
4.9l
4spd granny first
Accel tune up kit
Jeg's red hot coil
walker down pipe
jegs 2.5" flex coupler
4ft jegs 2.5" exhaust pipe
Moroso spiral flow muffler
just rolled 209,000 and still runnin strong
  #14 (permalink)
Old 07-05-2008, 12:54 PM
Motorhead351's Avatar
Motorhead351 Motorhead351 is offline
Motorhead351 is starting off with a positive reputation.
clifford dual out efi headers
cat(s) delete
X pipe (photo in gallery)
dual 2" pipe
2 generic turbo tube mufflers
turn downs are located on the muffler exits (photo in gallery)
  #15 (permalink)
Old 07-08-2008, 01:22 PM
6CylBill's Avatar
1994 Ford F-150
Here's another one;
And one more coming up shortly of me revving it from the outside. Keep in mind my vids are taken with a digital cam.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
Tags
300 , 40 , 49 , 49l , bogging , clip , clips , dual , exhaust , f150 , flowmaster , ford , series , sound , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
