Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 08-05-2008, 06:45 PM
6CylBill's Avatar
6CylBill 6CylBill is offline
1994 Ford F-150
6CylBill has a good reputation on FTE. 6CylBill has a good reputation on FTE.
Finally happy with it!
SI/ DO FlowSuper44.
3''/ 2.50''/ 3'' tips.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #17 (permalink)
Old 08-15-2008, 06:37 PM
6CylBill's Avatar
1994 Ford F-150
Here we go.
Cold start;
Short acceleration;
At idle;
A drive by; I plan on taking a better one sometime. I couldn't get on it like I wanted.
Six in a row makes it go.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #18 (permalink)
Old 09-09-2008, 08:58 PM
6CylBill's Avatar
1994 Ford F-150
Here's a take off; I didn't stomp on it too hard, the motor was still cold. It wouldn't matter anyway due to the camera. It sounds totally different when I open the throttle all the way.
Check out the frame flex. I thought it was pretty good considering it's a 2wd. Ford makes some excellent trucks. Even the cheap-o models like mine are still tough. All I need now is a rear locker.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #19 (permalink)
Old 10-18-2008, 11:48 AM
turdbird turdbird is offline
turdbird is starting off with a positive reputation.
Alright here's my true duals
96 F150 longbed single cab
both cats chopped off and true duals start where the downpipes would normally converge at the first cat, from there they each go into a walker high flow cat and continue over the rear axle and out the sides, the pipe is 2 inch with 3"x18" tips. this system has about 3 years of use on it
  #20 (permalink)
Old 10-26-2008, 09:50 PM
fiftyfordfloored's Avatar
fiftyfordfloored fiftyfordfloored is offline
fiftyfordfloored is starting off with a positive reputation.
Ok, here is my sloppy, rigged up exhaust... ready to take it to the shop and get the real one put on. Figured I'd post a clip of how the Flowmaster sounds on it, and I have to say, it ain't bad...
Specs:
1980 Ford F100 Flareside - 300 I6 (dur)
- Stock cam, EGR & A.I.R. Pump deleted
- Holley 470 Truck Avenger
- Offenhauser C-Series w/ 2 inches of carb-spacer
- Hedman Header
- Dual 2 inch pipes from collectors
- Cat-less
- Flowmaster 40 series (2 into 1) with 3 inch exit, dumping behind rear of the cab.
High idle ~850-900 RPM, Revving to 3400 RPM, and Idle with Load at ~500 RPM
__________________
1980 Ford F-100, 300 I6, C6, Flareside 4x2, 152K
1997 Ford F-150, 5.4L, Supercab Flareside 4x4, 254K
  #21 (permalink)
Old 10-26-2008, 10:54 PM
6CylBill's Avatar
1994 Ford F-150
Quote:
Specs:
- Hedman Header
- Cat-less
I just love your truck man. I can't get over how good looking those older Ford trucks are. I will say you're not going to get much better sound out of that 300. The way you have it now sounds excellent, I'd leave it be. The only thing you can do to it is make it quieter. If you do want to make it quiet and have duals, run a SIDO Flowmaster 50 series. If you want it loud, keep what you have and have the exhaust shop run duals for you. Or straight pipe it. You can get a kit from Jegs that'll let you straight pipe it. All you'll need is another Y pipe since you have a split manifold.
Your 300 sounds like it has a racing cam??
You have the 10 series Flowmaster, not the 40.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #22 (permalink)
Old 11-20-2008, 10:37 PM
Jhughes4707 Jhughes4707 is offline
Jhughes4707 is starting off with a positive reputation.
whats up guys im kinda new to the site... i plan on putting pics of my ole truck up on here soon. its a 89 F-150 300I6 no mods really to the engine 6'fabtech suspension lift and 3'body lift with 38' all terrains, blacked out. . . and i recently cut everything from my Muffler on down off =] so about 2-3 ft of exhaust pipe and also the muffler... i still got 2 cats on there but it sounds pretty good haha.. it gives me a loud roar that i like :P although over 4-5thousand rpms it backfires...but ill never need to go that high
  #23 (permalink)
Old 12-02-2008, 10:43 PM
TallPaul's Avatar
TallPaul TallPaul is offline
TallPaul is starting off with a positive reputation.
'95 F150 4.9L. Only mod is the muffler, a Flowtech Raptor, with short pipe exit in front of rear tire. Several clips:
__________________
'95 F150 XL, 2wd, 300 I6, 5 speed, 3.08 gear, 166,000+ miles, Flowtech Raptor muffler, driven hard for fun!
'92 Aerostar 3.0 Vulcan V6, auto, 134,000+ miles, Dynomax Super Turbo muffler
www.HonestEdu.org
  #24 (permalink)
Old 12-13-2008, 09:13 PM
havi's Avatar
havi havi is offline
Collector of rust
havi is gaining momentum as a positive member of FTE. havi is gaining momentum as a positive member of FTE.
I know, I know, sorry to waste yer time with my sound clip.
__________________
The going, the journey, should be the objective of a trip in a built old Ford, the destination always secondary.
  #25 (permalink)
Old 12-13-2008, 09:35 PM
6CylBill's Avatar
1994 Ford F-150
Quote:
Didn't waste my time.
Your sound clip was one of the first I heard that really got me wanting to mod my exhaust -so I can blame you for all the money I put out.
I do love the way your truck sounds. What did you do to it to make it sound like that?
Carb'd 300's just sound better than EFI's for some reason.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #26 (permalink)
Old 12-13-2008, 10:09 PM
havi's Avatar
Collector of rust
pre egr YF carb, stock intake, efi exhaust, walker downpipe, 2.5" exhaust running out behind the rear wheel with thrush cheapy turbo muffler. Nothing real fancy. It's got 250,000 miles on it, so maybe it's aged like an old acoustic guitar, lol.
Maybe with the bronco wheelbase, the pipe length is pretty short, and the sound is affected by that?
__________________
  #27 (permalink)
Old 12-13-2008, 10:44 PM
6CylBill's Avatar
1994 Ford F-150
The length does make a big difference. If you weren't a gearhead and wasn't really listening, you might have mistaken mine for a 302 when I had my exhaust exit in front of my rear tire. Now I have it behind the tire and it sounds like a big I6 (which I really like. I think it sounds good).
Yours sounds pretty aggresive though. It's one of the best 300's I've heard. Of course I love that I6 sound, not everyone does.
You have me on the miles, but not by a whole lot my friend. I'm on nearly 212,000 miles myself.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #28 (permalink)
Old 12-31-2008, 09:16 PM
6CylBill's Avatar
1994 Ford F-150
I thought this made a good sound clip so I decided to post it here.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #29 (permalink)
Old 01-09-2009, 02:16 AM
Milwaukee1979F150's Avatar
Milwaukee1979F150 Milwaukee1979F150 is online now
Milwaukee1979F150 is starting off with a positive reputation.
Quote:
Wow I do want that in E250 and 89 F150 I am sure it good by look at video it seem it didn't slip to other side it just both tires.
What those locker go for? $500?
__________________
Sorry for my bad grammar.
79 F150 4wd 4 speed Project
91 Bronco XLT 5.0L AOD. Replace intake, heads, and exhaust then install snowplow.
Currently drive 94 geo tracker until Bronco is ready.
  #30 (permalink)
Old 01-10-2009, 05:18 PM
Finally got a new clip up of my truck.
It lost some of the muscle car sound, but it's a lot nicer on the inside taking a long trip (and my truck is a Custom, which means no sound proofing).
__________________
Tags
300 , 40 , 49 , 49l , bogging , clip , clips , dual , exhaust , f150 , flowmaster , ford , series , sound , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
