Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-27-2008, 04:19 AM
86F150302's Avatar
86F150302 is starting off with a positive reputation.
"slow steering"
MY truck doesn't turn very fast, If I turn one way then back the other quickly the steering wheel gets hard to turn and it wont turn fast. (kinda hard to explain)
Any cure for this? It sucks when trying to turn into parking spaces and backing up to stuff.
__________________
Red 94 F150 Lightning
Ford motorsports shorty headers.
Borla catback exhaust.
Kicker 12" L7 sub.
Hifonics bxi1208d amp.
86 F150 302EFI
DJM 3/5 drop.
much much more.
  #2 (permalink)
Old 04-27-2008, 04:50 AM
81-F-150-Explorer has a good reputation on FTE. 81-F-150-Explorer has a good reputation on FTE.
Could be the power steering pump being shot, or the steering gearbox is worn out or improperly adjusted.
  #3 (permalink)
Old 04-27-2008, 06:32 PM
86F150302's Avatar
Quote:
How can I adjust it?
__________________
Kicker 12" L7 sub.
86 F150 302EFI
DJM 3/5 drop.
much much more.
  #4 (permalink)
Old 04-27-2008, 10:18 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE.
The first thing I would do is check/tighten the pump belt. If you have wide tires on the front, you will have to live with some of this too.
__________________
Dave F
1989 F250 XLT Diesel
  #5 (permalink)
Old 04-27-2008, 10:33 PM
86F150302's Avatar
Quote:
ok ill check the belt tomorrow. I have 235/75/15s
__________________
Kicker 12" L7 sub.
86 F150 302EFI
DJM 3/5 drop.
much much more.
  #6 (permalink)
Old 04-28-2008, 07:25 PM
Holmesuser01 is starting off with a positive reputation.
How fast does your truck idle? If it is idling slowly, you will have low pressure from the pump.
Have you checked the PS fluid lately?
I replaced my power steering pump about 2 years ago. It was whining all the time since the previous owner let a leaking hose drip instead of fixing it. The new pump really made a difference in the assist on the gear. Much nicer.
Good Luck!!
__________________
1983 F-150 w/ 351 Windsor, C6 tranny, A/C, and cruise. 180K, and everything works!
Now if I could just get it to pass gas stations.
  #7 (permalink)
Old 04-28-2008, 09:22 PM
86F150302's Avatar
Idles at about 700 rpms
I check the fluids every 3 days before I drive it. Always has plenty of fluid.
__________________
Kicker 12" L7 sub.
86 F150 302EFI
DJM 3/5 drop.
much much more.
  #8 (permalink)
Old 04-29-2008, 11:25 PM
It's a complicated proceedure in the book, to adjust the steering gear. I would write a book if I reprinted it here...
however, the adjustment screw is right on top of the gear box, it has a standard screwdriver slot, with a lock nut on it.
Also, check your kingpins, or balljoints, and tierod ends and steering linkages for binds, looseness, lack of grease, or damage.
Hope this helps.
  #9 (permalink)
Old 04-30-2008, 08:54 AM
86F150302's Avatar
Hope this helps.
ok thanks
I just got 4 new ball joints for my dream beams so maybe it will help.
__________________
Kicker 12" L7 sub.
86 F150 302EFI
DJM 3/5 drop.
much much more.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
