Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-18-2001, 05:14 PM
ExplicitHP is starting off with a positive reputation.
Stroker Kit
I have a 1983 351 windsor that has already been bored .030 over. How much more machine work is required if i install a 428CI stroker kit?
-Jon
  #2 (permalink)
Old 11-19-2001, 02:03 PM
chilly390 is starting off with a positive reputation.
Stroker Kit
It actually requires less machine work than a standard rebuild since you don't have to recondition the rods or crank. You'll still have to make sure all your clearances are ok, but this is the same as any rebuild. You will have to notch the bottom of the cylinders and the pan rail, but this really isn't machining, it's just grinding on them until you see .100clearance.
  #3 (permalink)
Old 11-20-2001, 05:17 PM
Rosati's Avatar
Rosati is starting off with a positive reputation.
Stroker Kit
__________________
Rosati
64 F100 with a few upgrades.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
