08-14-2001, 10:07 PM
351 police
Unless the 2700, or was it 7200? V V carb changed a lot over the years, the only feedback mechanism from computer to carb was a stepper motor screwed into one side of it. The stepper motor just opened more, or closed more, an air bleed port in the carb. The motor had something like 6 wires going to it.
Don't know why they are avoiding the AOD. The only thing AOD about the carb would be the need for the lever on the throttle lever assembly for the TV cable to attach to. The TV cable varies the trans internal control pressure depending on how far the throttle is open. Don't screw that up or leave it off, the adjustment is somewhat sensistive. Will throw off the shift points, and make the trans slippy, not good for internal clutch life. Used to say that any adjustment of greater than 50 RPM in idle speed required resetting the TV adjustment.
