Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-26-2008, 11:57 PM
Cowboy34 is starting off with a positive reputation.
Question wiring diagram for 79 Ford Lariat
my 78 Ford F150 4x4,the cab has rust on it above the front windshield very bad so i bought a 79 Ford F100 Lariat and it has had a carb fire and some of the hoese and wiring is burnt and i plan on switching the cabs and need a wiring diagram since te lariat has more things than a Ranger XLT.HELP!!!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-27-2008, 09:26 AM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
I would look on ebay for a diagram or manual. It should have pictures of the harness layout too.
But really if you are organized and do not get in a hurry, you should have no problems just switching everything over. The 78 wiring is good correct? So if you swap everything from the 78 over to the 79, everything should fit. If the 78 had gauges, and the 79 does not, you will need to swap all the wiring and the clusters over.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 04-29-2008, 12:23 AM
also since some of the wirse under the hood might be burnt and need to be replaced would or could i put a piece of tape on each wie and label it and plice the wire or rather cur the wire that has had heat on it and add a new wire to it with a wire connector and use tape or heat shrink tubbing around it
  #4 (permalink)
Old 04-30-2008, 12:27 AM
Franklin2's Avatar
I do not have a complete understanding of what you are doing? If you have two trucks there, and one has burnt wiring and the other does not, why not use the good wiring and plug it in?
__________________
Dave F
  #5 (permalink)
Old 04-30-2008, 05:23 PM
the one that just has burnt wire under the hood has more things in the cab than my Ranger XLT like in cruise delay wipers cargo light and etc
  #6 (permalink)
Old 04-30-2008, 05:38 PM
Franklin2's Avatar
The delay wiper wiring is all under the dash, as well as the cargo light. The cruise would probably have some wiring under the hood. I would look at both trucks and compare the wiring very carefully. You may find the wiring that is burnt, might exist in both trucks, and you would be able to just swap that part of the harness in.
__________________
Dave F
  #7 (permalink)
Old 05-01-2008, 09:48 PM
jpj64 is starting off with a positive reputation.
Check this out I use it all the time great site if you have multiful vehicles.
Johnny
Reference Databases Descriptions - St Johns County Public Library System
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
