Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-22-2001, 10:30 AM
GendoIkari69 is starting off with a positive reputation.
351W junk yard engine to rebuild....
But I want a carbed version and I hear they are hard to find. If I got a 351W EFI what would I have to change? The Bronco I'm putting it in currently has a carbed 351W so I'm assuming nothing needs to be done to the truck. I'd like to put an Edelbrock performer package on the junk engine when it's rebuilt.
__________________
1986 Ford Bronco
351W HO bored .030 over
Crower 15935 cam
MSD dist, coil & ignition
Holley Truck Avenger Carb
Custom guage pod hopefully coming soon!
  #2 (permalink)
Old 11-22-2001, 10:54 AM
ExplicitHP is starting off with a positive reputation.
You need to change camshaft, and intake.
  #3 (permalink)
Old 11-22-2001, 01:35 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE.
Why would you have to change the camshaft? I converted a EFI 302 to carb, and I had to change the intake manifold, add the fuel pump eccentric to the front of the cam, bolt on different timing cover for fuel pump, swap distributors, and swap valve covers so the pcv connections would work out. If you have two 351w's sitting there, one EFI and one carbed, swapping necessary parts from one to the other should make it possible.
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 11-22-2001, 04:53 PM
caddy 53
Caddy 53 is starting off with a positive reputation.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
