Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters and Ram Air
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 04-26-2008, 10:08 PM
Stumpalump is starting off with a positive reputation.
Ford Edge Cold Ram Air
3.5L 265 hp Edge. The airbox has two inlets. One that feeds up to the grill. The grill needs to be opened up between the crome slates to directly force air in. Thats not the good part! The other inlet is a 1" tube that sucks heated under hood air. When you remove this tube, Ford was so kind as to leave a perfect oval port that a standard homer dryer vent duck slips right on. A zip tie is all you need to hold it. You can then run the duck down behind the grill and either open up the bottom valence to force air in if you have the fog lights or the factory air dam has a removable cutout for the light that when removed lets air rush right into your dryer duct. Almost free forced cold air induction! With the grill inlet still attached it will never suck enough water thru the air dam to make it to the air box so you can hammer away in the rain or thru water.
Sponsored Links
To remove this ad, register today!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
