Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-26-2008, 09:46 PM
wmayo is starting off with a positive reputation.
Performance and MPG 4.0 Ranger
So here it is
I have a 1998 4x4 4.0 Ranger.
Started to see performance problems about six months ago. I just move to
San Diego and had to get it smog. It passed which suprised me for as bad as it was running.
Afterwards I had some time to do some maintenance on it. Changed the plugs, plug wires and air filter.
plugs 1 and 4 were broken in half and had been for some time. Needless to say the truck ran better afterwards. Still the gas mileage was really bad, 12 mpg. I notice the engine temp was not ever getting higher than 1/4 on the gage and it took forever for it to get there. Changed the thermostat. Temp now goes up 1/2 the way and does so in 10 mintues. also runs better with more power. Still it seems to be lacking pwr and after 120 miles I have already gone though 1/2 a tank.
Question: is there something to do next? there are no codes or engine lights. I had engine check light before the work but when I changed the plugs and wires I reset the ecu.
I was wondering if since the thermostat was stuck open the engine would have been running rich. Could this have cause problems for my o2 sensors, foul them up enough to cause mpg and performance problems but not enough to throw a code?
Also since the #1 and #4 were not firing for whatever amount of time would this have caused o2 sensors problems.
I have also run injector cleaner, gumout, for the last three tanks. How would you know if they was a clogged or partuially clogged injector? Best way to clean them?
Like I said it is getting better but still going through alot of gas and still a little weak when going up hills.
In closing it is a testament to the 4.0 and its ecu for the truck to pass a dyno smog with two broken plugs and a thermostat stuck open. That or the smog station really sucked.
Thanks for the help
  #2 (permalink)
Old 04-28-2008, 02:14 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Look at your printout and see what numbers it posted. You may have been at the high end of the scale.
Misfires are not good for cats. Yours are working, but I wonder if they started to melt from the extra heat of burning up the gas from the two dead cylinders. Not easy to check them...but someone mentioned a pressure test at the oxygen sensor port. Maybe you could research that test to see if you have a partially pluged cat.
Good luck.
  #3 (permalink)
Old 05-09-2008, 11:04 AM
TheHandyman is starting off with a positive reputation.
I sorta agree about the 'cats'. I've seen partly clogged ones that really killed an engine's power yet it continued to run for years! They'd cause extra back pressure if partly clogged. If no other way to test them, they could be cut off, visually inspected and replaced.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
