Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-25-2001, 08:25 PM
jmacjr1125 is starting off with a positive reputation.
4bbl intake on 302
I currently have a 1970 F100 with a 302 2bbl carb.I am going to put in a rebuilt shortblock with heads and want to put a 4 bbl carb.I know I will have to have another intake and new carb but is there anything else I need to consider?Or should I just stick with what I have?
  #2 (permalink)
Old 11-26-2001, 12:11 AM
Franklin2's Avatar
Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE.
4bbl intake on 302
[updated:LAST EDITED ON 26-Nov-01 AT 00:12*AM (EST)]Should go on with no problems. When you put the end seals on the block for the manifold, either glue them on, or throw them away and use a thick bead of silicon. You will have to make up a new fuel line for the carb, but should be easy. Make sure you use a good inline fuel filter (clear ones are nice).
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 11-26-2001, 08:48 AM
slikness's Avatar
slikness is starting off with a positive reputation.
4bbl intake on 302
The heads on your 2V 302 will have smaller runners than the 4V heads. This means that you won't be able to utilize the full efficiency of the 4V carb since the gas and air won't flow as well. The combo will work, but you'll see a big jump in hp and torque if you can change your heads at the same time.
Slik
__________________
Slik
300-I6 to 351W
  #4 (permalink)
Old 11-26-2001, 11:17 PM
Franklin2's Avatar
4bbl intake on 302
[updated:LAST EDITED ON 26-Nov-01 AT 11:18*PM (EST)]The only difference I've heard about on a 302 4v head vs 2v head is the chamber size. And that was for a couple of years only anyway. Should bolt right on, no problems.
__________________
Dave F
  #5 (permalink)
Old 11-27-2001, 11:54 AM
Todds79's Avatar
Todds79 is starting off with a positive reputation.
4bbl intake on 302
__________________
Todd
79 F100 Lariat 351w/C6
76 F250 Crew 390/NP435/Dana24/
Dana60/60
85 F250 429/C6/D44/D70 5.79/300ft Mud Racer/Dirt Drag
79 F150 Lariat 460/C6
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
