Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-19-2001, 11:22 AM
Todds79's Avatar
Todds79 is starting off with a positive reputation.
DOOE heads on a 85 351HO
I am swapping an 85 351HO/C6 combo into a 79 F100 that has a 302/C4 now. I have a set of NICE DOOE heads that I could put on this motor. Are the original heads on this motor ok, or would the DOOE heads work better? I think I would have to buy hardened pushrods and new rockerarms for the swap. Might be better to sell the heads and use the money for upgrades on the HO. Thanks for any help and answers!
P.S. Just found this site yesterday, this is great!
__________________
Todd
79 F100 Lariat 351w/C6
76 F250 Crew 390/NP435/Dana24/
Dana60/60
85 F250 429/C6/D44/D70 5.79/300ft Mud Racer/Dirt Drag
79 F150 Lariat 460/C6
  #2 (permalink)
Old 10-28-2001, 10:08 PM
85bronco is starting off with a positive reputation.
I have a 85 351W HO in my Bronco w/ a C6 and it ran awsome until I blew an oil cooler line and blew up. I am now rebuilding it and using thstock head because they worked fine for me. I do recommend you get the heads serviced w/ nex valve seals and seats but other then that I would see the other heads and buy and Edelbrock intake.
  #3 (permalink)
Old 11-12-2001, 06:12 PM
Spike8 is starting off with a positive reputation.
Post DOOE heads on a 85 351HO
If I were you I would check with a knowledgable source before swapping heads. If my memory serves me the D0OE heads in question are 58-60cc heads and the factory heads on your HO are 67cc and have similar if not marginally larger valves. The valves withstanding the older heads would put a 8:1 ratio engine (yours) closer to 10:1 and although you would feel far more low end pull, you would have to run race gas to keep it from detonating badly.
J.W.
KEEP IT ON THE LEFT FOOT!
  #4 (permalink)
Old 11-22-2001, 05:14 PM
caddy 53
Caddy 53 is starting off with a positive reputation.
I bought an 85 f150 4x4 w/c6 and 3:50 gear's I put 135,000 miles on eng w/o problem. However it was not ever a match on performance with 85 or 86 f150 with a inj 302and aodtran. I suggest keep it matched up. When you remove head's be ready to say HOW FAR DO I GO.ITMay be time to overhawl and put '96 roller cam.concern's: computer,oxg. sensor YOU know these were the remaining year's for mixed technology8
PS What are these head'd off of?
  #5 (permalink)
Old 11-26-2001, 05:38 PM
DannyP is starting off with a positive reputation.
The DOOE heads do have around a 60cc chamber so they would raise your compression to around 9.4 to 1 which is perfectly acceptable on cheap pump gas as long as you don't dial in too much advance. The stock valve sizes on these heads are 1.84-I and 1.54-E. The heads on your 85 HO are likely only 1.78-I and 1.46-E with about a 68-70cc chamber.
If I were in your shoes I would bolt on the DOOEs. If you decide against using them let me know, I may be interested.
DannyP
__________________
'93 F350 4x4 SRW reg cab, ZF 5sp, 5.9 Cummins, BHAF, 3.55s, 4" exhaust, gauges galore, 12k Warn winch, hydroboost
  #6 (permalink)
Old 11-27-2001, 11:54 AM
Todds79's Avatar
Thanks for the help. I have talked to a pro engine builder and we have decided to use the original heads on the engine. These are factory 302 heads with a 70 cc chamber. Guess they used the 302 heads for better low end torque. I had the block decked to 5 thousands in order to get a square block and raise my compression to 8.9 to 1. Using the DOOE heads would have raised my ratio higher than wanted for a street/pulling engine. I have added a Comp cams dual pattern 4x4 cam and an Edelbrock intake to the combination. Should make for good off-idle torque.. Also we went through the heads and upgraded the springs and seals. I will probably sell the DOOE heads--completely upgraded SS valves, screw in studs, new bronze guides, ported, etc.
__________________
Todd
Dana60/60
  #7 (permalink)
Old 11-27-2001, 08:46 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE.
__________________
Dave F
1989 F250 XLT Diesel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
