Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-26-2008, 07:59 PM
uchitz is starting off with a positive reputation.
Question 1987 cold and hot start problems
Done sofar and working ok: cyl. compression check, glow plug test, fuel lift pump pressure and flow test, replaced all injectors, copper washers and o-rings, caps and connector hoses and clips, filters ok and tight, replaced all rubber fuel ines from tanks to tank selector valve and forward to primary filter and to lift pump, replaced return hoses, visually checked the tank selector valve, functioning ok. Wore 87 starter out and replaced with re-man 84 starter.
Question if fuel shut off valve/timing could be an issue - how to test? How to test if fuel pressure remains in HP segments while engine is shut off? Is there a check valve somewhere?
  #2 (permalink)
Old 04-27-2008, 08:19 AM
Lazy K is gaining momentum as a positive member of FTE.
Did you plug or bypass the water seperator? These give problems. I bypassed mine.
  #3 (permalink)
Old 04-27-2008, 08:43 AM
Lazy Kay - My truck does not have an OEM water separator. I have a Racor pre-filter with a water separator, without electrical hook-up. The truck runs fine, once the engine runs.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
