Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #106 (permalink)
Old 01-21-2009, 12:55 AM
rollerstud98 rollerstud98 is offline
rollerstud98 is starting off with a positive reputation.
huh? Just wait for the new motor to come out, mileage is supposed to be up
  #107 (permalink)
Old 01-21-2009, 03:19 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
Quote:
Originally Posted by Passin Thru View Post
Duramax for fuel mileage it is. Ford sux anymore. They could get it a lot higher I believe if they tried.
The Ford Trucks weigh more and have more frontal area, yet you expect them to get a lot more mileage? GM, Ford and Dodge all got hit hard in the mileage department with 07 emissions.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #108 (permalink)
Old 03-19-2009, 09:14 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE.
Quote:
Originally Posted by a-rod View Post
If you look close that front end is just kinda cobbled together for testing I guess, they either pushed the bumper out farther or brought the grill in more from the looks of where that hood latch is. That hood is ugly as heck, I hope thats just temporary.
Exactly. The article said it's a mule with the most important feature being the engine. MPG's sounds real good, HP/TQ #'s sound real but if the mule is an indication of the final design, then I'm very disappointed.
Tim
__________________
SCPO United States Coast Guard Retired
'04 Expedition XLT 4x2
'99 Taurus Wagon SE 24V
'88 F-150 4x4 XLT Lariat 5.8L 5Spd
Rights of Passage: CPO Initiation, Submarine Qualified (SS), Golden Shellback, Blue Nose, Order of the Ditch
  #109 (permalink)
Old 03-20-2009, 10:24 PM
Fandini Fandini is offline
Fandini is starting off with a positive reputation.
Who is this "passin Thru" guy. Seems like each one of his posts are promoting duramax and trashing the Fords. What kind of BS is " my dmax will run circles around my OLD 7.3" I'm pretty certain the 7.3 powerstroke will run circles around the old Detroit that was in the GM truck before the D-max. I know the 6.0 powerstroke will run circles around the Detroits as well as the 1st gen D-max's. So what! Engine improvements come year after year..... as they should! Hell, my current TV is MUCH, MUCH, MUCH, better than my previous one. That doesn't mean that Sony makes a POS! Get a clue "Passin Thru"!
  #110 (permalink)
Old 03-25-2009, 09:35 AM
strokinout strokinout is online now
strokinout is starting off with a positive reputation.
A big problem is that, it was said before, Ford keeps changing their engines and both Dodge and Chevy have pretty much kept the same engine designs since the duramax came out and the cummins came out years and years ago. They've had plenty of time to work out bugs and improve their designs and if Ford would keep this engine for more than three years, it could be made to be a hell of an engine. They would have plenty of time to work out any possible bugs. I still want an I6! lol
  #111 (permalink)
Old 03-25-2009, 04:11 PM
An 07 5.9 cummins is a lot different then an 89 5.9 Cummins. Sure the basic design is similar, but heads are different, pistons are different, injection systems different. The 6.4 PSD is pretty much a punched out 6.0, with different injection system. Ford has not really changed their engines all that much.
__________________
- Ian
  #112 (permalink)
Old 03-25-2009, 09:50 PM
I mean it's been a step by step process and little was changed at one time until recently when they went through having to figure out how tmeet emissions standards. The duramax changed very little and while the cummins might have had only a head change here and injector pump change there, Ford didn't change too much until 2003 and that's when things for the powerstroke got bad. Don't know if I'm getting across what I'm really trying to say here. By the way, does anyone know if the 6.4 has two or four bolts per cylinder in the head?
  #113 (permalink)
Old 03-25-2009, 10:02 PM
origcharger origcharger is offline
origcharger is gaining momentum as a positive member of FTE. origcharger is gaining momentum as a positive member of FTE.
Quote:
Four bolts, just like the 6.0
__________________
2004 E-450 6.0 137,500 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
  #114 (permalink)
Old 03-25-2009, 10:19 PM
Do you know if they are the same maliable material? I'll be in the position to finally get a new Ford in October and am trying to figure out whether I should wait for the 6.7 or go ahead on the 6.4.
  #115 (permalink)
Old 03-29-2009, 02:22 PM
4X4X4RV's Avatar
4X4X4RV 4X4X4RV is offline
4X4X4RV is starting off with a positive reputation.
If I am out of line let me know...
I like how everyone says Ford changes this or Ford changes that or Ford is a piece S&*^. when they state Cummings not Dodge has not changed thier engines much, or Chevy, Izuzu which to Me is just like thier basic line 454.350 which really never changes thier basic design ( if it works use it ). After all We do have Internation to blame If we get down to it, As for Me I can't wait to see the new Ford Peugeot diesel truck engines, after they are doing quite well with thier smaller diesels ( research Fiesta diesel ) at a claimed 75 miles a gallon and eco green, until then I'm happy with my Ford/International and all it's quirks .......
__________________
72' F250 Crew 4x4 Project
85' F250 4x4 460 Stock
03' Ranger Super cab 2x4 4.0 Stock
04' Excursion 4x4 6.0 PSD 4" Lift Pro Comp (all leaf factory block) 35" Pro Comp X at's 4" MBRP turbo back
  #116 (permalink)
Old 04-17-2009, 10:50 PM
Greg B Greg B is offline
Greg B is starting off with a positive reputation.
6.0L could be a great engine. Whoever the idiot is that came up with the idea to use ten 10mm torque to yield head bolts per head on a forced induction compression ignition engine should be sentenced to 20 years of replacing head gaskets on those engines without the benefit of raising the body for access. And the high pressure oil pump and egr cooler could have been a better design also. The 6.4L engine is similar except the ten head bolts per head are 14mm torgue to yield instead of 10mm. Still not adequate. Both engines should have had standard head bolts or head studs originally. Would have saved Ford and Navistar both a ton of money. I also would have kept my 05 6.0L. I won't be buying another Ford diesel until I know for sure that Ford got it right.
  #117 (permalink)
Old 04-18-2009, 01:30 AM
I don't see any 6.4s blowing head gaskets yet because of stretched bolts, and they run quite a bit more boost them 6.0s as well.
__________________
- Ian
  #118 (permalink)
Old 04-18-2009, 10:50 AM
That's because they've increased the size of the bolt. But it's still a torque to yield bolt. Eventually they will stretch and fail. It just won't happen until the warranty has expired. Torque to yield head bolts have no place being installed on a forced induction compression ignition engine with 17.5:1 compression. That tells everyone that the stockholder is more valuable to the companies than the customer is. When the auto industry gets it's priorities in order and begins looking out for the customer instead of the shareholder first as Henry Ford's business model did, they will again see prosperity and great profits. If they don't put the customer first, then even Ford will see their ecomonic fortunes in ruin like GM and Chrysler. And we will again see great trucks and cars if they put us, the customer, first. And in case anyone doubts that Ford values the stockholder more than its cutomers, why is a F-250 that has far more capability than an f150 only a few hundred dollars more than that comparably equipped f150? Why did the price of the vehicles built in Mexico have the same sticker price as before production was shipped to Mexico? And why should I have to spend another $2500 to $4500 to make an engine that I've already paid a hefty premium to have ($5000-$7000) live a long life like they are supposed to? I must see evidence that Ford is putting the customer first before I'll by another new truck or car. That means building a product that does not need major repairs in the 1st 100K miles at an affordable price. It also means that it shouldn't cost $500 to have a new heater core installed or $200 labor for a tune up. I shouldn't have a spark plug break off when changing them. I shouldn't have a HPOP or EGR cooler go bad before 150K miles. I also shouldn't see a wheel bearing failure before 200K miles. Are you listening, Ford?
  #119 (permalink)
Old 04-18-2009, 02:32 PM
aortizexcursion's Avatar
aortizexcursion aortizexcursion is offline
aortizexcursion is gaining momentum as a positive member of FTE. aortizexcursion is gaining momentum as a positive member of FTE.
Quote:
I get your point and it's a good one at that, but realize that Ford is changing their ways. Also keep in mind that Ford and every other auto maker is running a business.
With that said, your sign off should of read "Are you listening, entire auto industry?" They're all guilty of it.
__________________
A. Ortiz
2000 Excursion 5.4 4X2
  #120 (permalink)
Old 04-18-2009, 05:09 PM
tseekins's Avatar
The failure rate in Ford's diesel program has grown exponentially over the past fews years. It's supposed to get better and more reliable as technology increases. I want a Ford diesel truck really, really bad, but I'm very,very afraid to buy one. There's no proof that the new 6.7L will be any better.
Tim
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
