Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #16 (permalink)
Old 04-28-2008, 08:03 PM
SUPERDUTY_untouchabl's Avatar
SUPERDUTY_untouchabl SUPERDUTY_untouchabl is offline
SUPERDUTY_untouchabl is gaining momentum as a positive member of FTE.
I am sure the competition will have the same hp and tq numbers. But hopefully fuel mileage will go up. Not likely though if the freakin epa wont back off.
__________________
-Josh
04 F150 4.6l Gryphon Powered 2wd reg cab XL 3:55 LS SISO Flowmaster S40 NCD Customs 2.5" Leveling Kit Burner High Power Fog Lights 285/70/17 BFG A/T KO's
  #17 (permalink)
Old 04-28-2008, 08:37 PM
deereman39's Avatar
deereman39 deereman39 is offline
deereman39 is starting off with a positive reputation.
Drats i was hoping for new version of the 8.2 ford 6 cyc.
Ed
  #18 (permalink)
Old 04-28-2008, 10:01 PM
BigJake86's Avatar
BigJake86 BigJake86 is offline
BigJake86 is starting off with a positive reputation.
The front grille looks like an '08 thats been lobbed off to accept the overbite of the hood. I think with the correct grille the truck might look okay. I really like the looks of the '08's, though.
__________________
2001 Excursion Limited 4x4 7.3 DP Tuner & F5 24MPG
1993 F-350 2wd Dually 7.3
1989 F-600 6.6 5+2
  #19 (permalink)
Old 04-29-2008, 03:44 AM
parkland's Avatar
parkland parkland is offline
parkland is gaining momentum as a positive member of FTE. parkland is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by dzldude View Post
ya know in way i like the new stile but in a way i dont.i hope its a i6, there easy to work on
They used to be. Now, there just easeyER....
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
  #20 (permalink)
Old 04-29-2008, 02:26 PM
a-rod's Avatar
a-rod a-rod is offline
a-rod is gaining momentum as a positive member of FTE. a-rod is gaining momentum as a positive member of FTE.
If you look close that front end is just kinda cobbled together for testing I guess, they either pushed the bumper out farther or brought the grill in more from the looks of where that hood latch is. That hood is ugly as heck, I hope thats just temporary.
__________________
Adam - - Collision/Refinishing Tech
2002 7.3 POWERSTROKE
100,000 miles
Straight Pipe, 6637, HPX line, pryo gauge, Foil Delete, WW, 6.0 IC + TC. Superchips Tuner.
F-350 Rear Blocks, Leveling kit
  #21 (permalink)
Old 04-29-2008, 07:19 PM
It actualy wouldnt suprise me to see a redone SD when the new motor comes out.
__________________
-Josh
  #22 (permalink)
Old 04-29-2008, 11:57 PM
KING's Avatar
KING KING is offline
KING is starting off with a positive reputation.
Highly interesting to say the least.
Hopefully there is going be a good candidate to replace my '07 when it can't run anymore and reads 400K+ on the clock.
__________________
2007 F350 KING RANCH LB CC 4X4 DARK COPPER WITH 4.5" ICON LIFT ON 35" BFGOODRICH A/T
-BLEW HEADGASKETS AT 55K, REPLACED UNDER WARRANTY WITH STOCK BOLTS..... ARGH!
  #23 (permalink)
Old 05-01-2008, 09:44 PM
handyman43358's Avatar
handyman43358 handyman43358 is offline
handyman43358 is gaining momentum as a positive member of FTE.
That hood has to just be temperary. Look click on the closeup picture of the front end, and look at the gap between the hood and fenders on either side. The gapping is off a bit. Hard to tell what Ford will do next. Hopefully they will stick with this 6.7. Too many engine changes the past few years.
__________________
Chad
1991 Ranger XLT 2.3 5 speed with over 328,000 miles
1995 F-150 XL 4x4 5.8 351 with a 5 speed ZF Manual. 240,000 miles
  #24 (permalink)
Old 05-01-2008, 11:50 PM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
Well I hope they do better than the 6.0 did when it first came out, or the first few 6.4 diesels that came out, But they will never get any mileage if the EPA keeps choking them down with emissions crap, I don't understand why we can't take a torch and cut all that crap out, but I'm sure they got it where the truck won't ever run at all if you do that.
__________________
1997 F250 Crew Cab 4x4
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
(3) 1986 F350 6.9 Diesel
1983 F350 Diesel (3) 1976 F250 390 4x4
  #25 (permalink)
Old 05-02-2008, 02:20 AM
mnmwhit's Avatar
mnmwhit mnmwhit is offline
mnmwhit is starting off with a positive reputation.
7.3 was off to a bad start when it first came out and the 6.9 had problems too. I had a 95 7.3 turbo and it had problems, had a 96 PSD and it would release the surpintine belt when you let off the thottle....pulleys were not alligned just right.
Quote:
__________________
06 F-350, North Pole, Alaska
Brush Guard w/4 moose lites
Mobil-1 Turbo diesel truck oil
fuel filters every 10,000 miles
AstroStart auto start
98 gal Transfer flow tank
Rhino liner on the rockers
Wabasto-Blue heat
MBRP turbo back duels w/ no CAT
  #26 (permalink)
Old 05-02-2008, 07:32 AM
F350-6's Avatar
F350-6 F350-6 is offline
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Quote:
That seems to be the problem. If you decide to wait a couple of years to let the bugs get worked out then Ford has already switched to a new motor and your back to waiting again. It's hard to believe the 6.4 will only be offered for 2 model years.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 305,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #27 (permalink)
Old 05-02-2008, 11:25 AM
phillips91 phillips91 is offline
phillips91 is gaining momentum as a positive member of FTE.
the hood has been photo shopped..... you can see where they made the shadows too dark on the ridge lines of the hood. and if you look above the drivers side headlight you can see the little piece of the hood that is hanging down from where they didnt line their pasted image up right......very poor photo shopping job if you ask me.....
  #28 (permalink)
Old 05-02-2008, 12:09 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
Quote:
Ummm...No. Thats a piece of rubber weather stripping, you can see that it is because it is raised up, and those shadows look perfectly fine to me.
These trucks are worked on all the time when testing new engines and such. Holes are drilled for sensors and such, pieces may be unbolted on the spot if its affecting engine operation, which is why all the body panels are loose like that.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #29 (permalink)
Old 05-02-2008, 02:05 PM
--Ummm...No. Thats a piece of rubber weather stripping
blow the picture up and look at it. you can see a very distinct white box that has been pasted over the hood. directly above the drivers side turn signal. i have NEVER seen a shadow that has a perfect box shaped white spot in the middle of it. compare the shadows on the hood crease to the shadows on the rest of the truck(right above the cab steps if you need an example). it isnt even close. if you think the shadow in the hood crease isnt photo shopped, i challenge you to find one for me in nature that looks like that.....
  #30 (permalink)
Old 05-02-2008, 04:02 PM
Its still a piece of rubber, you can tell. Plus trying to tell if a picture is photoshopped is pretty difficult when the picture is saves as a hugely compressed jpeg, and there are artifacts all over the place. What reason would anyone have to photoshop the truck anyways?
__________________
- Ian
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
