Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-26-2008, 06:31 PM
2jhanna is starting off with a positive reputation.
throttle cable/linkage problem
at the engine end of the throttle cable assy (engine end), there is a orange tube plastic piece, then a spring, and as the throttle is depressed, the spring is compressed, and a black plastic tube slides into the orange tube.
the end of the orange tube is broken and sometimes the black tube binds, not allowing the throttle to be depressed.
anybody seen this ? any solutions ?
__________________
j.hanna
dovfd
`90,f450,7.3l,5speed,5.13axles
`97,f350,ps7.3l,auto,4wd
  #2 (permalink)
Old 04-26-2008, 07:52 PM
Catsailor is starting off with a positive reputation.
Yes, mine does the same thing, but only after I mess around under the hood - if I line it all back up it seems to work okay. However, my cable has some slack in it that I would like to get rid of. I thought of simply crimping on another little copper deal at the pedal end with the cable pulled taught.
__________________
Tom Hall
Rowdy Dog Racing #67
BMW Spec E30
1994 F350 TD, Waste-gated Banks turbo, 4" exhaust.
  #3 (permalink)
Old 04-26-2008, 09:36 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
Ford still has the throttle cable, but it is about 50 bucks.
Mine did the same thing, I cut the orange tube out with a die grinder, but you have to be very carefull of the cable inside.
I then ordered a new cable, so I am prepared for the day it breaks.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #4 (permalink)
Old 04-26-2008, 09:43 PM
rmalottwtes30's Avatar
rmalottwtes30 is starting off with a positive reputation.
You can also go to autozone or advance and get a throttle cable for it.
__________________
Ryan
1985 F-250
6.9 Diesel
Hypermax 3.5 exhaust
Injector Pump turned 1 flat
Homemade ram air intake
http://s32.photobucket.com/albums/d5...Ford%20Diesel/
  #5 (permalink)
Old 04-26-2008, 10:23 PM
thanks for the input, i found a new cable assy locally. but, i was hoping someone had a cheaper/easier fix.
__________________
j.hanna
dovfd
  #6 (permalink)
Old 04-30-2008, 06:22 PM
ford trans tech is starting off with a positive reputation.
my two cents , its much cheaper to replace the cable that it is to repair an accident
__________________
89 F-350 CREWCAB DUALLY
  #7 (permalink)
Old 04-30-2008, 06:45 PM
Happyreefer's Avatar
Happyreefer is starting off with a positive reputation.
Same thing happened to me. Paid too much money from ford, later found out Autozone had it for half the price.
__________________
1994 Crew Cab F-350 7.3 IDI Factory Turbo, E4OD, 4.10's, 35" Mud Terrains, ...All ISSPRO Gauges...Turbo Pressure Gauge, EGT Gauge, Water Temp Gauge, Trans Temp Gauge, Gear Venders Under/Overdrive
  #8 (permalink)
Old 04-30-2008, 09:35 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
Mines busted too, and has been since day one. So far no problems. Same thing happend on my F150, but I made a new sleeve out of copper, way more trouble that it was worth but its tougher than OEM.
The plastic is simply junk I'm afraid, very brittle.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #9 (permalink)
Old 04-30-2008, 11:10 PM
catfish101's Avatar
catfish101 is starting off with a positive reputation.
Just be careful when you mod the linkage. That end is a break over. It keeps you from messing up the gov. on your pump.
__________________
79/83/86/95 F-??? 6.9 4speed
94 350 4x4 SRW 7.3 factory turbo
1930 Model A Original
My wife has three of her own.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
