Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-28-2001, 08:10 PM
redhead is starting off with a positive reputation.
RTV, Gasket or both? for 1985 302 intake manifold?
me again,
looks like the rear part of my intake manifold is leaking oil. When I get up the nerve to remove and replace it should I use RTV, a gasket, both or what? Any other tips I should know prior to tackling this job? I relieved that it wasn't the rear main engine seal leaking though. Thanks for all the help...
I've tried to upload a pic of my old ford truck.....
redhead
  #2 (permalink)
Old 11-28-2001, 09:02 PM
caddy 53
Caddy 53 is starting off with a positive reputation.
[updated:LAST EDITED ON 28-Nov-01 AT 09:07*PM (EST)] GOOD looking truck. I had same problem w/ 351 and a good cleanup felpro or fomoco gasket w/ rtv at corner and 3 m weather strip cement work good for me on valley frt and rear. New gasket recm'ds all time contact fellpro.. Comment. GM say's to caot both sides intake gasket on4.3 v6. Gasket manf. dont admit that, BUT I seen that correct water getting into
intake& get burned...... white exhaust Looks like blown hd gasket I don't remember FORD using Holley 4 v on 302 in 85..I remember 2 bar & the beginning of fi
  #3 (permalink)
Old 11-28-2001, 09:49 PM
wisnowman is starting off with a positive reputation.
Just a little dab in the four corners will do it. Don't use too much though. Just a little strip maybe 1/2" long. Four strips of RTV on the Intake and another four on the oil pan is all you need to rebiuld an entire motor. Use more and you will likely pay for it later. I bought a van that had a 302 in it and when I took the motor all apart the oil pump pick up screen was completely full of this junk, that is what caused the thing to starve for oil, that and the previous owner must have kept running it anyhow, neither the block or crank was useable after that. Good quality gaskets are the trick, Felpro!!
Good Luck !!
  #4 (permalink)
Old 11-29-2001, 08:33 AM
slikness's Avatar
slikness is starting off with a positive reputation.
I use a clear silicone bead on the front and back of the intake manifold. I've never had a problem with them leaking and it provides a great seal.
Slik
__________________
Slik
300-I6 to 351W
  #5 (permalink)
Old 11-29-2001, 11:22 AM
Franklin2's Avatar
Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE. Franklin2 has a great reputation on FTE.
I always use the silicon only on the ends instead of the gaskets. You can use the gaskets, but do like the other poster did and use contact cement to glue them to the block. They squish out of position if you don't, and that is what causes them to leak later.
__________________
Dave F
1989 F250 XLT Diesel
  #6 (permalink)
Old 11-30-2001, 02:10 AM
lvstang is starting off with a positive reputation.
You should use some gasketcinch(or similar) on the intake to head gaskets. I haven't used the intake to block gaskets on the last 4 motors I've built. A bead of black or blue RTV has sealed everything from small block Fords to the big block chevy in my boat. Never had a leak.
  #7 (permalink)
Old 11-30-2001, 06:00 AM
Thanks tons guys. I think it is mostly leaking between the intake and engine block in the rear and a very small amount in the front too. I'll post a follow-up and tellya all what happens. It's gettin cold here so I might not shuffle around to this project for awhile. This message board/group is worth a great deal to me. I hope I can help with some answers tooo sometime.
redhead
  #8 (permalink)
Old 11-30-2001, 07:56 PM
caddy 53
AWL. REDHEAD, put on some warm clothes and get your knuckles dirty like the rest of usdo.
caddy 53.
  #9 (permalink)
Old 11-30-2001, 08:32 PM
rocky2 is starting off with a positive reputation.
I got some tips for you redhead.....I like to cut a few (3) 5/16's 3 inch bolts I think the intake bolts are and make studs for alignment purposes cuz when your bending over a 1981 pickup the fender sticks up not low like a 1979....you could easily mess up gasket.Also I like to coat both sides of cork back and front intake with some rtv lightly.Also I like to only put a bead arond top/bottom of intake gasket water area's in rear(circles).Then take out the studs after lowering intake in place.
  #10 (permalink)
Old 12-02-2001, 01:14 AM
ecarter50 is starting off with a positive reputation.
__________________
Red 94 Lightning #1075
77 F100 converted to 4wd
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
