Quote:
Originally Posted by Club Wagon
Did you inspect the supply tube & old EGR for carbon build up?
Did you confirm vacuum was not leaking to the EGR control?
Frequently the EGR doesn't need to be replaced-just cleaned. The supply tube can get plugged w/carbon. Especially on older trucks that may have marginal PCV, may miss an oil change, or be subject to mostly short hauls.
Vacuum lines are notorious for failing.
theres vacuum going to valve the old egr valve did not have sines of carbon
inside that i can see
