04-26-2008, 04:33 PM
Thanks Club,i finally tracked it down to a dirty connection to the pcm.as crazy as it sounds i was disconnecting all sensors one at a time with the test light pluged in to show the short,disconnected the ignition and short went away so i the disconnected the pcm and short also went away,plugged the pcm in again and short was gone so i assumed it was just a bad connection,van runs great! 260,000 and still running strong,knock on wood.Forgot to mention i hard wired the fuel pump just to test it and it worked fine but truck had no spark also which is what led me to the pcm.
