Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-26-2008, 10:22 AM
Catsailor is starting off with a positive reputation.
Diff question
I have ID'ed my diff via the drivers door label - shows code 45 which is a Ford 4.10 according to the list that I found from a previous post. However, it does not give any other info so I can't figure out which Mag-Hytec cover I would be able to upgrade to. Also, mine does not seem to have any fill or drain plugs. How do you change the gear oil?
Thanks,
Tom
__________________
Tom Hall
Rowdy Dog Racing #67
BMW Spec E30
1994 F350 TD, Waste-gated Banks turbo, 4" exhaust.
  #2 (permalink)
Old 04-26-2008, 10:31 AM
xgatorx1976's Avatar
xgatorx1976 is starting off with a positive reputation.
there should be a tag on one of the caver bolts. if not look on the front side drivers side there is a boss that will have a #70 in the center making it a dana 70 , otherwise its a ford 10.5 it should be a ford 10.5.
You could pretend you need parts for your diff call Napa and ask for a ring and pinion, they will have a few? that will pin piont which it is.
__________________
Randy
99.5 F350 Regency conversion kit 4x4 DRW
DP TUNER with: nostart,stock,high idle 1300,60t,decel,80e,120,140
Full 4" exhaust straight piped
6637 air filter
  #3 (permalink)
Old 04-26-2008, 10:34 AM
Any idea how to change the gear oil? I am towing a 44' gooseneck with 2 cars in it and I want to make diff oil change a regular maint. item.
__________________
Tom Hall
BMW Spec E30
  #4 (permalink)
Old 04-26-2008, 10:35 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation.
Quote:
Thanks,
Tom
45 = 1990/97 F350 / Sterling 10.25 / 4.10-1 / non Limited Slip / 7400 lb. Rear Axle Capacity
Info source: 1990/2002 Ford Light Truck Parts Catalog / Rear Axle Application Chart / Section 40 / Page 5.
(Parts catalog shows Sterling 10.50 used 1999/ on F250/350's)
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003.
1965 F100 Styleside Pickup / 390 w/Borg Warner T-85N 3 Speed Overdrive / Original owner.
  #5 (permalink)
pull the cover. replace the cover then fill with oil, i would use 85-140 gearlube or royal purple gearlube.
__________________
Randy
6637 air filter
  #6 (permalink)
Old 04-26-2008, 10:40 AM
Tag says 4.10 10.2 and a few other numbers and letters. Also, I found what looks like a drain and fill bung on the front / drivers side - has a square indent for special tool perhaps. But it seems too high for a drain and too low for a fill.
__________________
Tom Hall
BMW Spec E30
  #7 (permalink)
Old 04-26-2008, 10:44 AM
Excellent, thanks for the info. According to an article in Diesel World Mag the Sterling 10.25 is a great axle. What do you all recommend for gear oil and upgraded diff cover?
__________________
Tom Hall
BMW Spec E30
  #8 (permalink)
Old 04-26-2008, 10:48 AM
Quote:
So the little bung I found is really just a fill spot - and that is as high as the oil level goes?
__________________
Tom Hall
BMW Spec E30
  #9 (permalink)
Old 04-26-2008, 11:05 AM
Ford Parts Guru
I'll let the FTE members that own one of these answer your questions.
I haven't progressed past the F150 yet!
__________________
  #10 (permalink)
Old 04-26-2008, 09:23 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
That is the fill plug.
Fluid should be even with the bottom.
I use synthetic oil in mine 80 90 weight and add friction modifier if you have limited slip.
7.5 pints if I remember right.
A rachet and extension, 3/8" drive will get the plug out.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #11 (permalink)
Old 04-26-2008, 10:06 PM
Thanks Dave. I got the plug out today no problem and the oil level was good, but the oil was pretty dark so its getting changed tomorrow. I tow a heavy load and want to make sure the diff stays happy.
__________________
Tom Hall
BMW Spec E30
  #12 (permalink)
Old 04-27-2008, 01:14 AM
optikal illushun's Avatar
optikal illushun is starting off with a positive reputation.
TRV for the gasket, i used mobil one 75-90 full syn when i change mine.
__________________
93 F150 XLT 4x4
Modded 300/Built E4OD
RC 2 1/2" lift
33 ProComp MTs
15x8 AR 147's
Crane 503905 cam
Crane coil
Taylor wires
Hedmen headers
1988 F350 Custom 4x4
7.3 IDI/ZF
RayWel lid w/ Opti'ized ram air
"G" codes
True 2 1/4" duals w/ packs
315/75/16 ProComp Xtreme ATs
16x8 White waggies
Alpine/Infinity stereo
3G soon
  #13 (permalink)
Old 04-27-2008, 06:33 PM
Tom D is starting off with a positive reputation.
Sorry to jump in on your post but could you tell me about my diff. The driver's door frame says C-5. Don't see any tag on diff. Thanks Tom
__________________
93 F-250 7.3 Banks turbo, 3.5" exhaust 4" ram air K&N filter E40D 4.10. Pyro, boost, & tranny temp gauges. Tru Cool 28,000 GVW trans cooler. 100% BIO
  #14 (permalink)
Old 04-27-2008, 08:05 PM
C5 code
4.10 ratio
6250 capacity
FORD Manufacturer
LIMITED SLIP type
Can be found here,
Ford Axle Code Chart .: Articles
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #15 (permalink)
Old 04-27-2008, 08:36 PM
Quote:
Originally Posted by Dave Sponaugle View Post
C5 code
4.10 ratio
6250 capacity
FORD Manufacturer
LIMITED SLIP type
Can be found here,
Thanks Dave
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
