This has been posted on another site and explains why/why not....
Ok hear we go. I got in touch with Stanadyne Corp. and asked about our injectors, a topic that turns up often! Hear is the scoop.
"Although this is really a question for Navistar, I will provide you with some information.
There are three different injectors used in 6.9 & 7.3L engines - one for the 1984-1992 6.9's & 7.3's, one for the 1992 1/2 - 1994 engines that Navisatar referred to as the "P&E" (performance & emissions) engines and one for the 1994 turbocharged engines.
In reviewing the drawings I see that in addition to to different nozzle opening pressure for the injectors, there are a number of differences between the nozzles including:
different pintle diameters, pintle bore clearance, valve overlap length,valve extension etc. all which result in different valve lift vs flow characteristics and therefore result in the different injectors for the different engine applications."
Sincerely,
Mark Dionne
Manager, Product Support
Stanadyne Corporation
Pumps and injectors are matched to the specific engine builds/performance levels by year...... found on the timing gear tag.
92.5 E injectors and 5013 IP
94 TD G injectors and 5070 IP
Turning up the present IP may help you, you will need a pyrometer installed ..... read how to turn up the IP on Ziggsters page.....
Ziggster's page
