Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-25-2008, 09:36 PM
idaho211 is starting off with a positive reputation.
1963-64 ford 2 barrel float distance
Do any of you have the measurement specs for the distance between top of the float to top of carb base? The rebuild kit doesn't list 292. Would the measurement be different between dry float and wet float measurements as well. They do list 302 but varies from different years from 7/16-1/2 inch. Appreciate any help. I am almost ready to put on the carb.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-26-2008, 10:47 AM
46yblock is starting off with a positive reputation.
If your question isnt answered, try here Ford Carburetor Forum. Carbs rule!!!! .
The link is for a site dedicated to answering questions regarding Autolite 2100 and 4100 carburetors, with a few Hollys thrown in. The EXPERT is Bill White. Maybe he could also help with the Lincoln carb issue in the post below?
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
  #3 (permalink)
Old 04-27-2008, 07:20 PM
Thanks I will give it a try.
  #4 (permalink)
Old 04-28-2008, 11:53 AM
adharvey2 is starting off with a positive reputation.
According to the '63 supplement, dry float initial setting for the 2 bbl, "Top of float to be parallel with top of fuel bowl, bowl inverted".
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
