Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-25-2008, 12:55 PM
phillips91 is starting off with a positive reputation.
fuel mileage test results
I was reading an article a while back that was talking about the best ways to conserve fuel and it said that for every 10 mph you do over 55mph you lose 3-4 mpg. I decided to do some tests with different fuel additives and speeds. My driving style stayed the same for all tests with the only difference being my cruising speed. All tests were done on the same roads also(hilly terrain going from tn to wv). My truck is a 97 f250, reg cab, XL, 5 speed with 4.10 gears. Nothing in the truck but me(no tool boxes, passengers, junk, etc).
Trip 1- Plain fuel with no additives doing 55 mph. 363 miles/16.8 gallons=21.6 mpg.
Trip 2-Plain fuel with no additives doing 65 mph. 320 miles/17.2 gallons=18.6 mpg. Lost 3 mpg.
Trip 3-Added power service(white bottle) additive doing 55 mph. 350 miles/15 gallons=23.3 mpg.
Trip 4-Power service(white bottle) additive doing 65 mph. 393 miles/19.9 gallons=19.7 mpg. Lost 3.6 mpg.
It looks like riding around at 55 mph instead of 65 saved 3-4 mpg and the fuel additive helped about 1-2 mpg. I'm running the same tests with the power service gray bottle right now and will try it with lucas brand next.
  #2 (permalink)
Old 04-25-2008, 01:05 PM
c00nhunterjoe's Avatar
c00nhunterjoe has a good reputation on FTE. c00nhunterjoe has a good reputation on FTE. c00nhunterjoe has a good reputation on FTE.
i have noticed the biggest difference with staying under 5 psi boost and under 2000 rpm.
my max economy has been at 1500 rpm which is roughly 55 mph
__________________
The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again.
http://www.youtube.com/user/c00nhunterjoe
http://community.webshots.com/user/c00nhunterjoe
  #3 (permalink)
Old 04-25-2008, 01:13 PM
secondarychaos's Avatar
secondarychaos is starting off with a positive reputation.
It also makes a big difference that you have the 410's
3.55's, might be able to fudge a little higher w/out losing 3mpg
__________________
1996 Ford F250 powerstroke diesel
Running 285/75 Bridgestone dueler revos
Gauges: boost, pyro, tranny.
15.6K ICP
140V IDM mod... easy as pie
6637, 3" downpipe to 3.5" turndown right after t-case. EGT's wont go over 1100, boost to 25 psi, sounds awesome!
I think i have AB code injectors!
  #4 (permalink)
Old 04-25-2008, 04:59 PM
scatgo's Avatar
scatgo is starting off with a positive reputation.
Don't expect much from Lucas. Bad stuff. Read this additive test http://www.ford-trucks.com/forums/68...n-thelist.html
__________________
1994 F350 CC Dually
7.3 DI TURBO DIESEL
5 SPEED
HPX, FPR shimmed, Edge
Intake, Downpipe, Cat delet
  #5 (permalink)
Old 04-25-2008, 05:19 PM
97-psd is starting off with a positive reputation.
ditto for the 3.55s, there is a bright side to having the higher gears for sure. and if you have the time, try the 2-cycle for an additive and let us know how it works for you
__________________
1997 F-350 PSD CC SRW 3.55 5-spd 4x4 266,000 mi and counting
3.5" dp, 3.5" exh. with side-pipe, cOOn 14.7k mod, DIY intake, Stancor gpr, fpr shim and high hopes
1978 J-10 Sunday driver
  #6 (permalink)
Old 04-25-2008, 05:21 PM
Robbgt's Avatar
Robbgt is gaining momentum as a positive member of FTE.
I wish I could get myself to drive at 55MPH... The truck just runs so darn good that it likes to do 80!!!
@75-80 with TW: 18-19
@65 with TW: 21MPG
@55 I bet could hit 23... maybe
-Robb
__________________
97 F-350 XLT 4x4 PSD, E40D, 3.55's, 158K, 6637, 140V IDM, HPX, FPR Shim, Hotfoot, Tymar DP, Dual Exhaust, T/C Lockup mod, new GP's, Stancor GPR, fresh rebuilt trans w/ billet T/C.
SOON: Gauges, Stage 1's, 1.00 A/R exhaust housing, DP Tunes.
  #7 (permalink)
Old 04-25-2008, 05:27 PM
Cuda_jim's Avatar
<-The Engine Of Democracy
Cuda_jim has a very good reputation on FTE. Cuda_jim has a very good reputation on FTE. Cuda_jim has a very good reputation on FTE.
Very informative phillips91, keep up the good work. Reps sent.
Loking forward to your next test results.
I usually watch the boost age when trying to safe fuel, keep it under 5-6 psi and under 60 MPH seems to be my best....22MPG empty, dead flat terrain. Crew cab, 4x4, 4:10's. I only got that once though...when I first got the truck....18MPG is the best I get now.
__________________
Jim
96 PSD F350 4x4 CC LB 203º Stat, Coolant Filter, 6637, 3.5 DP, True Cool 4739 w/Therm, Built E4OD w/Triple Disk TQ
97 F150 Flairside 4x4 Ext Cab
1939 Ford 9N Sherman Trans
  #8 (permalink)
Old 04-25-2008, 07:37 PM
RÖENTGEEP's Avatar
RÖENTGEEP is gaining momentum as a positive member of FTE. RÖENTGEEP is gaining momentum as a positive member of FTE.
Question
@65 with TW: 21MPG
-Robb
In what tune TW: 80 econo??
BTW, very good test phillips91, also reps sent.
__________________
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; shim FPR; tranny cooler; CCV mod; 4" stainless Magnaflow; SS 5" tip; no cat; RacerX VB; TW 6p chip.
«Primum non nosere»
  #9 (permalink)
Old 04-25-2008, 08:28 PM
Robbgt's Avatar
Well, DP has an 80 Econo tune, Tony doesn't give his settings HP ratings because they differ from truck to truck. But yes it was in the Economy setting .
-Robb
__________________
  #10 (permalink)
Old 04-25-2008, 09:08 PM
RÖENTGEEP's Avatar
Talking
Gracias amigo.
__________________
«Primum non nosere»
  #11 (permalink)
Old 04-25-2008, 10:29 PM
jleal_21 is starting off with a positive reputation.
man those 20's sound pretty good, 18 is the best i get. no mods just use a hypermax tuner.
  #12 (permalink)
Old 04-25-2008, 10:54 PM
scatgo-after reading that article you sent, i think im going to cancel the lucas portion of my test lol. it looks like just plain used oil is better than the lucas.
robbgt-oh, it kills me having to do 55 mph too. but with my job i usually drive about 1000-1500 miles per week and i need to find the best ways to save on fuel. just doing 55 instead of 65 saves me about 10-15 gallons a week.
ive got all the materials to make a few test batches of bio too. once i get enough mixed up to amount to anything ill run some tests with it too.
about the 2 cycle oil....is there any particular brand that is the best to use, or just any old 2 cycle oil will do? this is my first diesel, so i dont really know what to try other than whats on the shelf especially for diesels.
  #13 (permalink)
Old 04-25-2008, 11:02 PM
Robbgt's Avatar
Quote:
Thats about how many miles I do in a month if that! Of course I go to school full time and live here, 200 mile round trip to go to-from home usually every weekend for work/see girlfriend. I don't know what I'd do if i drove that much a week!!!
-Robb
__________________
  #14 (permalink)
Old 04-25-2008, 11:17 PM
my normal round trip drive to work is about 80 miles. but i usually have two or three trips each week that range from 300-500 miles round trip. the good thing is that i get paid mileage for the long trips. im just trying to find ways to maximize my profits.
  #15 (permalink)
Old 04-26-2008, 04:21 AM
884x4broncoII is starting off with a positive reputation.
any tc-3 two stroke oil will be fine, split a quart between your two tanks, the super tech stuff from wally world is pretty cheep
__________________
96 f250 7.3L powerstroke
5spd manual
4.10 axel ratio
extened cab long box
superchips max tuner
6637 filter
no kitty
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
