Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-25-2008, 02:00 AM
twwtruck is starting off with a positive reputation.
Question filling up
ok ive only had a diesel about a month but if i go to the pump it will shut off if im barley pulling the trigger. i just wanted to know if there is a screen or breather that could be doing this and how to fix it
  #2 (permalink)
Old 04-25-2008, 02:07 AM
Temporarily Deactivated
northern 7.3 is starting off with a positive reputation.
only thing i do sometimes is pull the nozzle out of the filler neck a bit.. Sometimes that works.. other than that i just curse and keep going...or go to a full serve and let them wash my truck too when they blast the box side with diesel
  #3 (permalink)
Old 04-25-2008, 03:51 AM
tbone91 is starting off with a positive reputation.
As a temporary solution, try driving the drivers-side rear wheel up onto a chunk of wood (4x4/4x6 wedged on one end) when you fill up. I've never tried it, but have seen it mentioned here before.
northern 7.3, I think that these days, a short "blast of fuel" may waste more money than the free carwash is worth
__________________
91 F350 dually crew cab, Rebuilt E40D + TC, ATS turbo, stock intake & exhaust
  #4 (permalink)
Old 04-26-2008, 01:21 AM
1957F100 is starting off with a positive reputation.
My truck does the same thing. It can get very annoying...and ill admit it ive done the blast of fuel on the box side myself....only once though.
I would also like to know if there is something that can be done to stop this from happening?
__________________
1957 Ford F100 - 302 w/ C4. Work in Progress...
1993 Ford F250 4x4 - 7.3L Diesel, ZF 5 Speed
Mods - Soup Bowl Removed. Hypermax Cowl Air System Installed. Autometer Ultra Lite Gauges. 4" Straightpipe to 5" Stacks. SouthBend Clutch. Cowl Hood. Custom Paint Job.
  #5 (permalink)
Old 04-26-2008, 01:29 AM
speedrdr is starting off with a positive reputation.
yep, sure is something you can do if you want to go to the trouble of taking the fill tube loose from the truck and tank and removing the inner tube out. it gives you more room for fuel to go in. i'm assuming the front tank has this setup. i know the rear tank has about a two foot long inner breather type tube to let air out so it doesn't airlock(so to speak) while you're filling up. you might try that and see if it helps
speedrdr
__________________
'90 F-250 XLT 4X4 7.3 non-turbo 5-speed
'91 F-250 XLT 4X4 7.3 non-turbo 5-speed
'01 Dodge 3500 Cummins turbo 6-speed
'91 Honda CBR 1000F sportbike-very fast, much fun
  #6 (permalink)
Old 04-26-2008, 03:34 AM
ok thanks for the advice
  #7 (permalink)
Old 04-26-2008, 08:59 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
Both tanks have the vent tube.
And both tanks will fill faster without it.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
