Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-25-2008, 12:24 AM
92P72CrownVic is starting off with a positive reputation.
Right or wrong???
Maybe somebody here can answer this, Everytime I replace my oil filter I fill the new filter with with fresh clean oil before installing it. My father inlaw says I am wasting my time and oil. He claims it makes no difference and I say it shortens the time for the new oil to start flowing through the engine even if its only a second its still one less second of dry engine cranking. Any thoughts?
  #2 (permalink)
Old 04-25-2008, 04:52 AM
BChance's Avatar
BChance is starting off with a positive reputation.
How are you "wasting your oil"? You still have to put it in until it's full..and it doesn't use any more or less if you fill the filter first or not..total capacity of the system does not magically change and need more if you fill the filter..and as far as time.. uhhhhh...sure..what..30 seconds per change? 45 maybe? I can live with that.
Your doing right by your motor by filling it. Think about it.. oil from the pan comes up the pickup to the pump, from the pump it goes through the filter then into the galleys..if the filter is full, the pump has to move that much less to get flow into the galleys. Why not fill it and save what life you can? (Unless you have an old Rover..they lose the prime on the pump if you don't fill the filter and swap them fast...really fast..they cook in about a minute if that happens. On those, it's a requirement)
Anyway, in short, your father in law doesn't seem to have a real good grasp on how the oil system works, and you are right in your thoughts. The huge debate is how much it REALLY helps. I ain't willing to find out considering how easy it is to fill it.
  #3 (permalink)
Old 04-25-2008, 06:03 AM
rsylvstr's Avatar
Fleet Marine Force Doc
rsylvstr has a good reputation on FTE.rsylvstr has a good reputation on FTE.rsylvstr has a good reputation on FTE.
tell your father-in-law to put his apron on and get back in the kitchen
__________________
Semper Fi,
Rob
HMCS(FMF/AW)
USNR (now)
2001 Ford F150 SCrew Lariat 4 x 4
5.4L 4R70W 3.55 's
Hypertech
93 Octane
K&N Series 77 CAI Kit
Flowmaster cat back dual rear exit
Rancho RSX's
Cooper Discoverer ATR's
Nasta S/S step bars
Sarge's site
RIP 02/13/2008
  #4 (permalink)
Old 04-25-2008, 09:32 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
I do the same.. everything I know says starting an engine with no oil pressure is bad.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab 5.9(351 .030" over), FMS SEFI MAF Kit, Ported E6s, Crane 444232,
AOD, TransGo Shift Kit, 3:55LS, Flowtech Longtubes, TweecerRT
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #5 (permalink)
Old 04-25-2008, 10:14 AM
merlynr is starting off with a positive reputation.
One day on a cable reroute job where I was an inspector they were using a backhoe and at lunchtime the company mechanic came out and changed the oil in it and as we ate lunch I watched him and he filled the oil filter before installing it and I asked him what for and he responded,"so the oil will be picked up faster". Never thought of it before then, so I usually do it now. They had a whole fleet of construction eqpt,trucks,etc so I guess it made sense.
__________________
97 F250 4X4 7.5
71 F350 dump 360
99 Explr XLS 4.0
05 Mustang GT 5 sp
73 Mustang cpe
71 Mustang cpe
65 Mustang fastback
  #6 (permalink)
Old 04-25-2008, 12:18 PM
dragogt's Avatar
dragogt has a very good reputation on FTE.dragogt has a very good reputation on FTE.dragogt has a very good reputation on FTE.
Yeah, but you talkin about a 5qt system VS a 5-10gal system.
__________________
83 bronco
86 mustang gt t-top
83 mustang gt
Aaron - STGs Minions - Pirate Investigator
Quote:
Originally Posted by STGFordCrazy04 View Post
what? someone actually broke a TTB?
Im fabbergasted!
Quote:
Originally Posted by BradyCocuhman View Post
TTB AKA a baster chiled of a IFS and a solid axels drunken sex romp...
  #7 (permalink)
Old 04-25-2008, 01:04 PM
stans is starting off with a positive reputation.
I always put oil into the filter when I changed filters even though that was not in the service manual. It just made sense to me to have the filter saturated so the engine did not run for long without oil pressure.
  #8 (permalink)
Old 04-25-2008, 05:04 PM
mcdonaldm is starting off with a positive reputation.
if you have an oil pressure gauge and not an idiot light, next time you change oil experiment. fill the filter up and then start the engine. the gauge will probably take less than 5 sec to go to full pressure. next time don't fill the filter. i bet the gauge takes twice as long to reach pressure.
just have to do that experiment once to convince yourself to fill the filter up before you install it.
Rgds
Mike
  #9 (permalink)
Old 05-03-2008, 09:55 AM
60F100 is starting off with a positive reputation.
In addition to filling the oil filter you can also (on the pre computer vehicles) disconnect the ignition wire to the distributor and crank the engine until you build oil pressure. This prevents firing without oil pressure. I tried it on a computerized car and got a check engine light. I don't remember where I read this tip
  #10 (permalink)
Old 05-07-2008, 10:19 AM
tim.moman is starting off with a positive reputation.
For some vehicles, disabling the ignition is required as part of the oil change to prelube before it fires. Limits damage to the bearings. It is documented everywhere in every type of use that prelubing the motor for normal startup significantly reduces engine wear. Keep doing it
  #11 (permalink)
Old 05-07-2008, 10:23 AM
RDJ184's Avatar
RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.RDJ184 has a great reputation on FTE.
I always fill the filter.. but i want some of his magic filters... I could win some money with that
__________________
JOIN NEW MEXICO CHAPTER HERE!
RANDY 06 6.0 4X4
  #12 (permalink)
Old 05-09-2008, 07:32 AM
jade79 is starting off with a positive reputation.
I was always taught by my father and uncle to do the same thing. Even on motors where the filter goes on horizontally or angled like a 302, I still put what I can in there, just shy of it spilling out.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
