Spindle Bearing Replacement?
on
i have to replace the spindle bearings in my truck. but i dont know how. i tried a few differend ways to drive the old one out but nothing seems to work. are there any tricks to removing this bearing? i cant seem to get anything to grip the back side so i can pound it out.
also how do i change the spindle bore seals? they are the things that are attached to the outer axle shafts.
my shop manual seems to skip these topics.
thanks for any help.
on
i tried all sorts of angles, nut nothing that fits right is long enough to use!
couple of questions for you, i think i have the wrong mental picture of what you're talking about.
first whats a lady foot pry bar?
and if i understand the procedure correctly, i put the pry bar in from the side closest to the bearing then through the threaded end i use a regular punch and hit the pry bar?
This is a lady foot prybar
MacTools > Mac Tools: Product Details
You would insert the foot end into the back of the spindle to catch the bearing. You then angle the bar back to give it a better bite. Then take a punch through the other end and drive on the top of the lady foot bar.
Jason
Jason
on
i got it out! YAY!!! i went to sears and they didnt have any ladys foot pry bars, i i just got the 3 peice pro series prybars on sale. tried them and still didnt work! i tries some funny stuff, like fitting a washer over a punch and trying that, but the washer bent. finally i grabbed an old prybar with a thin strait tip. i bent the tip untill it hooked the lip of the bearing and it pretty much just popped out!
psu927
08-20-2010 10:13 AM
gibsonj
07-16-2005 02:02 AM
