Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #16 (permalink)
Old 05-01-2008, 10:40 AM
Marz-68's Avatar
Marz-68 is starting off with a positive reputation.
well my rust was very light but here are some picks of my rust removal.
  #17 (permalink)
Old 05-01-2008, 11:29 AM
GreenDinosaur is starting off with a positive reputation.
As far as a chemical rust remover i'm not sure, never had the luxury of using any. I beleive that those seal are called anti rattlers i'll have to look it up.
looks like marz-68 has what yer lookin for.
  #18 (permalink)
Old 05-01-2008, 10:51 PM
bigredball90 is starting off with a positive reputation.
wow looks like it did a pretty good job did it just dissolve it or did it turn it into another form of metal??
__________________
1970 f100, original 302 2bbl, 5sp out of a 90 mustang... 78k original miles
  #19 (permalink)
Old 05-02-2008, 08:01 AM
instig8r63 is starting off with a positive reputation.
Quote:
That Behr concrete stuff is liquid phosphoric acid. In gel form it's known as naval jelly. It does not turn it into another form of metal but it changes the iron oxide (rust) into black iron phosphate which can then be rinsed off. After removal of the rust and rinsing, the metal must be immediately dried, treated, primered (preferably with an epoxy type primer) and painted. Otherwise, left untreated, the bare iron, exposed to oxygen will immediately begin to cover itself with the iron oxide although initially invisible to the naked eye.
__________________
Bobby
1972 F100 Short Bed
1963 Uni Longbed 390/C6
1967 Mustang Fastback 390 4-speed
  #20 (permalink)
Old 05-02-2008, 09:49 AM
Marz-68's Avatar
What I did is I applied the liquid with a scuff pad and left it on for about 1 min or 2 and then I washed it down with warm soapy water then I dried the area quick and applied WD-40. I've been doing this for the past 3 years with not side efects on the metal.
We have also been doing this to this chevy way longer than mine.
  #21 (permalink)
Old 05-02-2008, 10:55 AM
ok were did you get the behr rust remover, walmart??
Sounds like it would be easier if you had two or more people helping you do it as well. Would it be safe to use inside the cab just let it air out before I got back in it and drove?
Thanks,
Luke
__________________
  #22 (permalink)
Old 05-02-2008, 11:46 AM
Marz-68's Avatar
I got this stuff at home depot and yes you will have to let it air out before driving your truck.
  #23 (permalink)
Old 05-16-2008, 05:25 PM
alright i got a rust remover and worked it on my driver floor panel to see what all it would do.
before
underneath
inside
during
Then I waited about 30 minutes and then dried it with a towel.
I then sprayed a clear rust inhibiter and then a grey primer on after it.
Im going to do the whole floorboard after i get either a new rubber floormat or carpet. O and its not really for sale unless someone wants to give me 2k or more than what I got it for.
Thanks for the help!
Luke
__________________
  #24 (permalink)
Old 05-19-2008, 09:48 AM
Marz-68's Avatar
For spots like that I would just hit it with a wire wheel first and then do the steps you did with the stuff you bought.
  #25 (permalink)
Old 05-20-2008, 11:21 PM
im planning on going back and sanding it down. and im looking into a restorer to get the whole cut out and a new piece of metal welded in and sanded down to look like it was always there
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
