Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-24-2008, 09:38 PM
foolforfords's Avatar
foolforfords is starting off with a positive reputation.
Good Info.
hello all, let me start by saying theres a ton of good info on this site, i bought my 05 350 cc psd used of course because im not wealthy, and i love the truck but there seems to be a smell of antifreeze when driving under load.I know that sounds strange but i smell it in the cab under those conditions.ford dealer said they cant find a leak? by the way the truck has 70,120 miles on it and its stock except for the exhaust, cant afford a programer yet.any ideas, am i headed for head gaskets soon? has any one else had this problem? thanks for any info. FFF
  #2 (permalink)
Old 04-24-2008, 09:59 PM
bismic's Avatar
bismic has a very good reputation on FTE. bismic has a very good reputation on FTE. bismic has a very good reputation on FTE. bismic has a very good reputation on FTE.
Are you losing coolant? Is there residue around your coolant degas bottle?
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
  #3 (permalink)
Old 04-24-2008, 10:12 PM
havent noticed any coolant loss , nor residue either, checked the oil also and it seems fine not trace of coolant?
  #4 (permalink)
Old 04-24-2008, 10:40 PM
tex25025's Avatar
tex25025 has a good reputation on FTE. tex25025 has a good reputation on FTE.
do you have any strange looking exhaust fumes? any high pitch whistling goin on other then the turbo?
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #5 (permalink)
Old 04-24-2008, 10:47 PM
brickie's Avatar
brickie is gaining momentum as a positive member of FTE.
Is the valley on the motor wet?
__________________
03/04 350 Crew DRW 6 speed XLT fx4, EconoMax injectors, Autometer Fuel, Boost & EGT. AFE filter, Sct X-III with some sweet Spartan tunes, ARP studs, RR fuel system, Southbend FB8, Fluiddamper, Ali Arc hunting bumper,Light Force, Ride-Rite helpers,Ford APCM
03 Ex LTD mostly stock motor and a bunch of bolt ons on the truck.
  #6 (permalink)
Old 04-25-2008, 06:33 PM
sorry for the delay in posting, after a good look at the motor I noticed some wetness in the valley seems to be behind the oil filter canister. cant tell were its coming from.any ideas? FFF
  #7 (permalink)
Old 04-25-2008, 08:33 PM
Jim McCarty is starting off with a positive reputation.
I'm sure glad you started this thread. I have also been smelling anitfreeze during a long hard pull - but thought I was dreaming because I have never lost any water.
I drained and flushed the system at 50,000 miles and carefully measured the water level in the bottle for reference. BTW, 50,000 is way ahead of what Ford recommends.
I have now driven it another 50,000 miles and it still does it - but no loss of water. In addition, I have a Blackstone analysis done every oil change and have never had water in the oil.
I'm baffled, but not worried since it is still full of water. However, I will go check the valley in the morning.
__________________
Jim
'06 F350, 6.0L. Auto Trans, King Ranch, DRW, CC, LB, MBRP Exhaust, big smile on face while driving.
'73 F100 390 with lotsa goodies
  #8 (permalink)
Old 04-26-2008, 10:02 AM
69cj is starting off with a positive reputation.
To Fool, if you see wetness in the valley then you have an egr cooler, oil cooler or cooler hose leaking and should be covered under 100,000 mile engine warranty. If you found this and the dealer couldn't, I would be looking for another dealer to do the repairs.
__________________
"05 F-250, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
