Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-24-2008, 09:09 PM
S.P. is starting off with a positive reputation.
Talking Battery cables
I see a lot of battery/starter problems and was wondering if anyone has tried to make their own battery cables? I bought the connectors for both batteries at Napa for $7 and $14 each, welding wire cables from a welding supply shop @ $3.30 per foot, propane torch and sodder. The total came to just under $70. That beats the heck out of $180+ for a new cable.
  #2 (permalink)
Old 04-24-2008, 11:23 PM
catfish101's Avatar
catfish101 is starting off with a positive reputation.
I make them all the time. I like to use welding cable also. I just did a burn job not long ago. Had to rewire a piece of equipment from the ground up. It took several feet of wire. At the price of wire now it gets expensive.
A few years ago I should mortgaged my place and bought every bit of wire I could find. I could retire now if I did.
__________________
79/83/86/95 F-??? 6.9 4speed
94 350 4x4 SRW 7.3 factory turbo
1930 Model A Original
My wife has three of her own.
  #3 (permalink)
Old 04-25-2008, 01:18 AM
Temporarily Deactivated
northern 7.3 is starting off with a positive reputation.
i put a new one on from ford a year ago it was signifigantly cheaper than that..125 or something like that. anyway. i looked into making my own (i am an electrican after all) but i would NOT use solder on connectors personally. The problem with solder is with the high Cranking amp you can heat it and gradually cause the connection to fail over time going right back to the same problem. Crimped on (compression) fittings are a far better route for longevity. Either way make sure you use GOOD quality heat shrink tubing around the joints. Good luck
1991 F250 4x4 7.3 ATS turbo
  #4 (permalink)
Old 04-25-2008, 05:06 AM
Dodge/Cummins is starting off with a positive reputation.
I've made (literally) a TON of battery cables. Northern7.3 is right, crimp them and use GOOD shrink tube. I always color code the cables with the shrink tube (pos. & neg.). You HAVE TO get the "hammer on" type crimping tool and assemble the cable off of the truck on a bench or something solid. There is nothing under your hood you want to beat on as hard as you need to to correctly crimp the cable ends/connectors.
BUT be careful not to hammer too hard or you can split the connectors.
Also don't forget to put the shrink tube on the cable BEFORE the cable connector or you'll get really mad at yourself. Not gonna' tell you how I know that.
Lastly make sure you strip the insulation the correct amount and push the cable all the way into the connector and keep it there while you crimp it.
End of "Battery Cables 101"
  #5 (permalink)
Old 04-26-2008, 03:28 PM
optikal illushun's Avatar
optikal illushun is starting off with a positive reputation.
i make my own and i solder and crimp.
__________________
93 F150 XLT 4x4
Modded 300/Built E4OD
RC 2 1/2" lift
33 ProComp MTs
15x8 AR 147's
Crane 503905 cam
Crane coil
Taylor wires
Hedmen headers
1988 F350 Custom 4x4
7.3 IDI/ZF
RayWel lid w/ Opti'ized ram air
"G" codes
True 2 1/4" duals w/ packs
315/75/16 ProComp Xtreme ATs
16x8 White waggies
Alpine/Infinity stereo
3G soon
  #6 (permalink)
Old 04-26-2008, 11:48 PM
Which do you do first?
  #7 (permalink)
Old 04-26-2008, 11:53 PM
speedrdr is starting off with a positive reputation.
don't k now if this falls in the category of solder, but the last set of cables i made up i melted some wheel weights and poured into the wire/connector. never had any problems with melting. a little more trouble than acid core solder, but effective
speedrdr
__________________
'90 F-250 XLT 4X4 7.3 non-turbo 5-speed
'91 F-250 XLT 4X4 7.3 non-turbo 5-speed
'01 Dodge 3500 Cummins turbo 6-speed
'91 Honda CBR 1000F sportbike-very fast, much fun
  #8 (permalink)
Old 04-27-2008, 01:43 AM
I might try that, I can't think of why it wouldn't work. If you stripped the cable, filled the connector part way (in a vice, on end) with the molten lead, then stuck the cable in and let it cool, Seems like it would be a good conductor and pretty fool proof. I would still use good shrink-tube though. Might have found another use for my bullet-casting equipment.
  #9 (permalink)
Old 04-27-2008, 02:28 PM
stevilknevil's Avatar
stevilknevil is starting off with a positive reputation.
Quote:
i think i would still crimp it though
__________________
'79 f-250 7.3 idi,4x4,4.56 gears,4-speed,some rust,lots of fun
  #10 (permalink)
Old 04-27-2008, 02:30 PM
i solder first then crimp the end before i heat shrink the tubing. thats the way i was taught in school (i went for both automotive and diesel). the only thing we didnt crimp were the actual battery terminals that slide over the post as they would split.
__________________
93 F150 XLT 4x4
RC 2 1/2" lift
33 ProComp MTs
15x8 AR 147's
Crane 503905 cam
Crane coil
Taylor wires
Hedmen headers
7.3 IDI/ZF
"G" codes
16x8 White waggies
3G soon
  #11 (permalink)
Old 04-27-2008, 02:34 PM
megawatt00's Avatar
Jaymi-Lyn says be a......
megawatt00 is a splendid one to behold megawatt00 is a splendid one to behold megawatt00 is a splendid one to behold megawatt00 is a splendid one to behold megawatt00 is a splendid one to behold megawatt00 is a splendid one to behold megawatt00 is a splendid one to behold
I have made up many of my own battery cables. Being an electrical contractor i have a set of heavy duty crimpers. I dip the stripped end of the wire into noalox (it is made by Ideal and you can get it at home depot) this will stop all corrosion. Crimp it and then heat shrink. The Noalox is electrically conductive so no problem there. it is an oxide inhibiting compound so there is no chance of oxidizing on the connector. You should also put this on the battery terminals before and after you connect the cable.
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back MBRP, 6637 w/ Custom Cold Air Intake,Autometer guages,The one and only DP TUNER
Rick,Will ,JD, What Are We gonna Do Now?
http://www.roadsidehelpnetwork.info/
  #12 (permalink)
Old 04-27-2008, 02:39 PM
Quote:
is that like the grease on electrical conections?
__________________
  #13 (permalink)
Old 04-27-2008, 04:03 PM
megawatt00's Avatar
Yes. It does look like a grease. You see it used alot on aluminum electrical connections. The stuff works great. I had to replace the cables on my cabover. i did it 3 years ago. the battery tops have been exposed to the weather due to no cover. There is not a smidgen of corrosion or oxidization.
__________________
Jim
2001 F350 4X4 DRW
  #14 (permalink)
Old 04-27-2008, 11:06 PM
can you get the same stuff at lowes?there is'nt a home depot close to me.
__________________
  #15 (permalink)
Old 04-28-2008, 10:19 PM
megawatt00's Avatar
You should be able to. They do carry the Ideal product line. If they don't have it for some reason do you have any electrical supply houses in your area? They would carry it. If you can't find it shoot me a pm and I'll send some to you.
__________________
Jim
2001 F350 4X4 DRW
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
